![]() | Home > Puma (Tdci) > Scangauge to kill EGR MIL? |
Just "freefalling" here, so apologies if this is a stupid question...
If I just unplug the EGR, I get a MIL after a few cycles. I read somewhere that you can use Scangauge to get rid of the light permanently. Is this correct and which Scangauge would I need? Matt p.s. I'm just experimenting, Gary - I'm still using your remaps as well ![]() But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 12th May 2012 6:57am. Edited 1 time in total |
Yes but Gary (Alive) has rigged my final remaps so the EGR wakes up and self-cleans when switching off. I had some problems yesterday with heat and power loss (even with the remaps) and I'm looking at several possible causes (sticking EGR, grubby/busted MAF, CHT cooked with engine blanket etc.)
I have a long trip coming up and the nearest dealer (I trust) is a long way away and can't look at the car for 2 weeks ![]() Plus I'm just curious about what Scangauge can do ![]() But shout it at them in German because life is also terrifying and confusing... |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Most/All diagnostic tools will reset the MIL light but if the EGR remains unplugged the MIL will illuminate again as the EGR has failed the test cycle because it is unplugged. The only way to permanently have the MIL switched off when the EGR is unplugged is to do so through rewriting the EMS software as Gary has done for you with the remap file.
Have a read of this post as it may be worthwhile getting this mod from Gary: http://www.defender2.net/forum/topic10564.html?highlight=egr+oem Scangauge here: http://www.defender2.net/forum/topic10829.html
Brian. |
Cheers Brian
![]() I actually already have a "EGR closed only" remap from Gary (he has excelled himself with customer support ![]() ![]() I'm posting it separately as it covers several issues. I would be interested to know what you think... Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
The Matzker device is an external software mod. It still does the same thing as a remapped file only more expensive than getting a OEM fuel file with the EGR closed from Alive. The EMS is programmed with parameters for the operation of the EGR and the only way to have the EGR bypassed without showing the MIL is by software. Or mechanically you could blank either end of the EGR and it will operate as normal without allowing the exhaust gases to be recirculated back into the inlet manifold as it will still be plugged in as far as the EMS is concerned.
Indeed (silly me) - I actually bought it with the 110 from new (with a load of other Matzker goodies) and never sold it as I could never get the 600 quid ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
Wouldn't mechanically blanking the EGR cause a MIL? Tell someone you love them today because life is short.
Have a look at the posts from Denis
![]() http://www.defender2.net/forum/topic12250.html |
![]() ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
copey28 Member Since: 11 May 2012 Location: Ayr Posts: 199 ![]() ![]() ![]() |
having trouble with my defender can someone tell me what mil means
Malfunction Indicator Lamp - just in case you didn't realise your engine was bug*ered when it stopped
cheers my engine managment light has came on and aint going off and blue smoke has started when i start it up in the morning any ideas?????????????????? ![]() |
Not an expert - perhaps a good idea to start your own thread as something like "Help! Blue smoke and warning light on"
Should get you some expert attention ![]() But shout it at them in German because life is also terrifying and confusing... |
@copey28, I should be down your way on Friday or Saturday taking the dogs to the beach. Drop me a pm if you want to meet up and I will bring a diagnostic tool with me, unless of course the one you ordered arrives and you have it fixed by then.
![]() ![]() Brian. |
