Home > Td5 > Mad sensor help
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Mad sensor help
Can any one telle the symptoms of when a maf sensor fails ??
Regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #144761 13th May 2012 5:26pm
bob neville
Sluggish bad performance seems to be the main symptom.
Have a read Thumbs Up
http://www.defender2.net/forum/topic10214.html
Have a Google with TD5 Maf sensor, plenty of reading on other forums about it.
it appears that if you disconnect the MAF and performance is better if could be faulty. Other thing I picked up is that genuine is the way to go but it is possible to fit a brand new MAF sensor and that can be faulty as well Shocked
Good luck.
2013 Defender 90 CSW - sold
Post #144762 13th May 2012 5:36pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Easiest way is to start the truck and move off immediately - try and get into 2nd gear quickly. If the MAF's dud there will be almost no power at all for 10 seconds or so, then a big jolt and it'll start working normally.
Post #144765 13th May 2012 6:00pm
big steve
yer does seem sluggish
doesnt seem to want to go muich past 50-55
and would it also make fuel consumption poor Confused
Post #144768 13th May 2012 6:15pm
bob neville
I would say fuel consumption would suffer, you would not be getting the correct mixture.
Post #144771 13th May 2012 6:21pm
big steve
i think ill be ordering one tommorow 2015 2.2 tdci hardtop xs
Post #144772 13th May 2012 6:24pm
twopoint6khz
If it won't go above 50-55 I wouldn't think it'd be the MAF sensor.
Reason is, the ECU tries it to start with, but if it's getting duff readings it just reverts to a default set of values and carries on. This is why the car is sluggish but then there's a big jolt - that's the ECU realising the MAF is dead. The default values will allow the engine to run ok, but not perfectly.
It's like that with a few things - errors will make the engine run worse, but as far as I know the only one which will cause the engine to stop is the crank position sensor. Everything else it can compensate for.
Be worth plugging it in to a diagnostic machine before blowing £90 on a new MAF.
Post #144775 13th May 2012 6:42pm
robpenrose
Just disconnect it and see if there is a difference. If there is a big difference and much more power with it disconnected, then it's dead.
If your buying a new one, make sure it's a decent one, not a cheapy.
Think Siemens are decent... Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #144780 13th May 2012 6:57pm
big steve
yer will order a genuine one
its more the sluggish bit it will go faster but does seem to take a long times getting there
dont get me wrong on my old td5 90 it was tuned and went really well but wasnt as sluggish as this when it wasnt
my puma standard goes better on 35s that the td5 disco
Post #144804 13th May 2012 8:55pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Use A quick Google search "testing maf sensor".
The autoshop101.com result may be of some use, third Page. Shows how to test with a multimeter.
Post #144819 13th May 2012 10:11pm
