![]() | Home > Td5 > Mad sensor help |
Sluggish bad performance seems to be the main symptom.
Have a read ![]() http://www.defender2.net/forum/topic10214.html Have a Google with TD5 Maf sensor, plenty of reading on other forums about it. it appears that if you disconnect the MAF and performance is better if could be faulty. Other thing I picked up is that genuine is the way to go but it is possible to fit a brand new MAF sensor and that can be faulty as well ![]() Good luck. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Easiest way is to start the truck and move off immediately - try and get into 2nd gear quickly. If the MAF's dud there will be almost no power at all for 10 seconds or so, then a big jolt and it'll start working normally.
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
yer does seem sluggish
doesnt seem to want to go muich past 50-55 and would it also make fuel consumption poor ![]() steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
I would say fuel consumption would suffer, you would not be getting the correct mixture.
i think ill be ordering one tommorow 2015 2.2 tdci hardtop xs
If it won't go above 50-55 I wouldn't think it'd be the MAF sensor.
Reason is, the ECU tries it to start with, but if it's getting duff readings it just reverts to a default set of values and carries on. This is why the car is sluggish but then there's a big jolt - that's the ECU realising the MAF is dead. The default values will allow the engine to run ok, but not perfectly. It's like that with a few things - errors will make the engine run worse, but as far as I know the only one which will cause the engine to stop is the crank position sensor. Everything else it can compensate for. Be worth plugging it in to a diagnostic machine before blowing £90 on a new MAF. |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Just disconnect it and see if there is a difference. If there is a big difference and much more power with it disconnected, then it's dead.
If your buying a new one, make sure it's a decent one, not a cheapy. Think Siemens are decent... Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
yer will order a genuine one
its more the sluggish bit it will go faster but does seem to take a long times getting there dont get me wrong on my old td5 90 it was tuned and went really well but wasnt as sluggish as this when it wasnt my puma standard goes better on 35s that the td5 disco steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
Use A quick Google search "testing maf sensor".
The autoshop101.com result may be of some use, third Page. Shows how to test with a multimeter. |
