Home > Off Topic > Winch Blanket Advice!
Page 1 of 3 123>
Zagato
There is one hell of a strain on the anchor point/webbing etc when I pull the boat onto the trailer. Is a winch blanket the sort of thing I need to prevent the strap flying back if something gives way. Where are you meant to put the blanket or other devices - near the anchor point? Anyone have a good cheap source of what I need...
Guess who did a lifeboat launch first try Rolling Eyes Pretty spectacular though :lol:
Post #144746 13th May 2012 3:47pm
roamingman
You could use a blanket or even an old coat, heavy sack, placed in the mindle of the line, Smile Live Life Ti'l You Die
Teddys are out thier
http://teddybearspicnic.webs.com
http://130sasha.co.uk/
Post #144747 13th May 2012 4:00pm
We sell our own branded winch blankets on our site
They can be placed anywhere along the cable and will help to drop the cable to the ground in the event of a break
Nice launch Thumbs Up
Post #144748 13th May 2012 4:14pm
landy andy
I have one of these
http://www.ebay.co.uk/itm/winch-safety-bla..._968wt_922
It is very very very well made, arrived next day, useful pockets, and cheaper than any other winch sail
Or if you want cheaper use an old coat, put it over the cable and then zip up the coat
Post #144750 13th May 2012 4:21pm
Zagato
Thanks....have to say even weighted I'm not sure how effective it would be, the strain on the strapping is significant. If there is nothing else known on the market I think I will rig up something that would physically hold the line down towards the trailer and move it up once or twice as the boat comes up!
Post #144773 13th May 2012 6:37pm
BigMike
No need to spend money on a winch blanket. Just wrap a thick jacket round the the rope. Job done. With that kind of winch just stand well to the side when operating it.
Post #144798 13th May 2012 8:30pm
richuk
I would have the trailer much further into the water. Realise that means regular bearing maintenance, but would be safer and less stress on winch and boat. Rich
semper in excretia sumus solim profundum variat
Post #144800 13th May 2012 8:37pm
TJ101
Ditto,, Back her in a couple of extra feet Zag
Looks like someone has already clouted the end of the pontoon !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #144823 13th May 2012 10:25pm
roamingman
Yes get trailor into water more, let boat float onto trailor, before winching. Smile Live Life Ti'l You Die
Post #144830 13th May 2012 11:13pm
leeds
Looks like yo have flat webbing as your winch rope.
Webbing when it breaks tends to make a noise and will tend to break the warp threads one at a time at an increasing speed. Keep a watchful eye on edge cuts which can significantly weaken the webbing, also be wary if 'fur' appears on the surface. A common place for webbing assemblies to fail is at the edge of the stitch block so be doubly wary of abrasion or nicks in this area.
Is it possible to get a pulley block for this webbing line? If so you could double line halving the load on the line (thereby reducing possibility of it breaking) but doubling the amount of line you have to take in.
Brendan
Post #144831 13th May 2012 11:24pm
AndrewS
Fit a mesh guard to the trailer 130's have feeling's as well you know Smile
Post #144834 14th May 2012 7:37am
Zagato
I could have backed the trailer in a few more inches but it's designed specifically so you don't have to get the wheels/hubs wet, clever design but makes it bloody heavy at 1000KG and long. The previous owner took out a petrol pump with it Rolling Eyes
I have some heavy elastic line which I can thread through a bit of pipe to stop it catching on the strap then hook both ends down to the trailer without much strain... I thought there would be something for off-road winching but I suppose there is nothing to hook it down to unless you maybe hooked it sideways with a ground anchor of some sort...It's the advantage of using an electric winch with a remote of course... Could look into that, it's what the previous owner used!
Tim not guilty, but the pontoon wasn't like that when we arrived Confused 30 Drascombe boats came on the rally, not a bad turn out for a miserable, cold, wet few days of sailing.
Post #144838 14th May 2012 8:01am
landy andy
Personally I would put tow bar on the front bumper, or 2" receiver, and then use winch attached to the defender.
Andy
Post #144897 14th May 2012 12:33pm
Zagato
Unfortunately the winch would be too low... shame though! The angle of pull would be too low plus it would obstruct the pivoting bed and front post which is necessary to hold the boat in position. It's designed to have a hand or electric winch fixed to this post at the right height as with other trailers. Previous owner used an electric winch on this post and had long leads with crocodile clips to his battery, not a great set up. Hand winch will be fine with the strapping held mid way Thumbs Up
Post #144901 14th May 2012 12:43pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
First thing I would do Zag is get rid of that webbing and replace it with Dynema, you never see cranes using webbing.
I would also consider replacing that winch, I have witnessed some horrors with those things coming physically apart under load, they may be rated at 2 or 3 ton but I would never trust one with anything bigger than a 8' tender.
On my boat trailer I have a small electric super winch from David Bowyer, with a 15' long remote that allows me to stand well clear of the winch line. Richard
Either a 90, 110 or 130.
Discovery 5
Post #144916 14th May 2012 1:53pm
Page 1 of 3 123>
