| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Came third in the Twinaxle / Flanders L R Club cane trial in the FCX tray back
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge It was a wet weekend ! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Put the truck on the back of an AA truck...front bearing seized and smoking
took it to the local 4x4 shop to get fixed.....2 new front bearings on both sides as they both are knackered and a full service all oils in diffs G/box changed all new filters £270 all in with the bearings here http://www.bellautomotive4x4.co.uk/ NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
I second that :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338
Hand brake stopped working, took in to garage to look at. Oil seal gone and brake pads soaked up the oil.
New seal, brake shoes all fitted and now working. Then tightened the bottom rear door hinge as the door was making a very bad rattle... Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
I remember the days when we used to soak oily handbrake shoes in petrol overnight and set fire to them in the morning.
Current price of petrol probably means it's cheaper to buy new shoes. ![]() |
Haha that's a good idea. It's the second time in 2.5 yrs it's happened. Blooming annoying... Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
still think 10" wide wheels are the bizzo! |
when you can get 5 years out of them and get them change for £50 buck each...i recon so maybe you know best ? what should i use then ??????? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
| chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897
Thirded! just needs a pretty bird in the foreground then it could be straight out of the Stihl calender Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Beer 'n Sex 'n Chips 'n Gravy ![]() |
| cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375
Worthy of a L.R ad' pic' that is.
Fitted jate rings to front. Not to back though. Have to remove tank to get old bolts out and new un's in. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo Last edited by cinstone on 6th May 2012 4:25pm. Edited 1 time in total |
| tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436
| kjmeijer Member Since: 09 Apr 2012 Location: Netherlands Posts: 84
I took it for a longer drive and after a few hours the power was gone. Pressed the gas but no reaction and it kept slowing down Stopped, shut down and restarted. No power problems anymore untill now. Any ideas?
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
case of switch-it-off-switch-it-on ... bit like a computer. if you have some space cash, have a look at the ultragauge or a scangauge and you can read any fault codes from your truck |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489
