Home > Technical > webasto fuel tap anyone ?
Anyone with a webasto .. have you fitted or considered fitting a fuel line tap ?
Post #141207 23rd Apr 2012 7:41pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
yes but didnt do it in the end. rather leave the original fuel system alone.
I understand how it is done and that the webasto pump should seal off, avoiding the webasto to flood under pressure of the original lines but i really preferred to do it this way:
(pics off blacklandy.de)
also saves the hassle of warranty, insurance and MOT in case something goes wrong with the fuel system.
my 2 cents only
Smile
PS: BPMan I PM'd you earlier about this, dont know if you've got my message.
Post #141214 23rd Apr 2012 7:50pm
yes thanks tarra805 I did get your messages.
I am still undecided how to tap into the fuel system, but thought a fuel tap might take the pressure off the webasto when not in use.
I am meeting some more owners in May and I will have a look at their installations too.
Post #141224 23rd Apr 2012 8:14pm
jst
now that solution from Tatra seems a very good way of doing it. in fact i may revisit fitting one with that idea. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #141237 23rd Apr 2012 8:40pm
I agree, but I would also fit a protection plate to stop stones and muck from damaging the fuel pipe.
Post #141274 23rd Apr 2012 10:00pm
tatra805
Thanks but credit where it belongs... the pictures are from the german forum, so not my idea
i did it as described here,.. http://www.defender2.net/forum/topic7878-30.html
Been doing lots of off road lately and no leaks. as long as it holds i wont change it.
Smile
Post #141283 23rd Apr 2012 10:31pm
dgardel
Italy
I made a hole on the rear floor (like the 99% of the vehicle on the road).
This is not my photos, it came from internet (I'll do same photos during the weekend)
This is the measurements for the 90
http://ilmiodefender.altervista.org/botola90.pdf
and this one for the 110
http://ilmiodefender.altervista.org/botola110.pdf
and I installed this one
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #141288 23rd Apr 2012 11:14pm
pom
the webasto has its own in-line fuel pump. In fact I have a brand new one in a bag somewhere...
pom
Post #141366 24th Apr 2012 12:23pm
My concern is the fuel pressure running up against the webasto pump or the webasto unit itself
And if there is any need to isolate it during the summer
Post #141372 24th Apr 2012 1:57pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
I installed a eberspacher in a merc vito, using the merc instructions.
In this application, i tapped into the fuel return line with a T, worked fine.
Post #141377 24th Apr 2012 2:25pm
pom
there is no pressure, it feeds from the tank directly.
Post #141408 24th Apr 2012 5:32pm
tatra805
Pom, the schematics of the puma fuel system are out here somewhere on the forum.
You have 2 loops
1 between filter/cooler/pump
1 between filter and tank
You are half right saying there is no pressure but only in the second loop.
The first loop is always under pressure, also the return to the filter. This is where people plug in the T as it is the nearest position to the webasto water heater. But it can become a problem once the webasto in-line pump starts leaking and fills the webasto with fuel. + getting air in this side is problematic.
If you plug into the second loop, you can as well go to the tank directly as you are that close to the tank already.
If you T-off into this return line you will suck dry air if not on a full tank as the pipe does not go deep enough.
If you T-off in the suction line you risk again that the webasto pump will not seal off one day and the puma fuelpump will start sucking air trough the webasto. As the puma fuelpump is not self-priming it is a bad idea to my opinion to disturb this fuel line.
2cents
Smile
Post #141419 24th Apr 2012 6:46pm
this is exactly my point, so I am thinking that I can install a fuel-cut-off tap on the feed to the webasto pump for the summer and when the unit is not going to be in use for long periods.
something like this
Post #141424 24th Apr 2012 6:59pm
dgardel
Italy
No way to install the Webasto fuel line on the Defender loops.
Every time that someone tried the slight loops pressure "disturb" the Webasto (rich and/or irregular burning)........
You need an independent line...
Also a non-return valve on the small water pipe on the expansion bottle...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #141434 24th Apr 2012 7:11pm
I know about the non-return valve Thumbs Up
I'm just looking at all the options to connect into the fuel and there are a few
1. seperate tank - ok but no fun filling in the arctic circle
2. T into the existing ... no problems reported by constant pressure on the webasto pump + isloation tap
3. Bean-Can and pipe fitting like Tatra805s - looks to be a good idea but where can I get the fitting from ?
4. drop tank and fit seperate pipe direct into tank like COBS - will i be able to drop the tank without breaking it ?
5. cut hole in floor and tap directly into tank like dgardel - not keen on cutting hole in defender floor
I think i'm going to drop the tank - option 4 ... we're moving house soon so I will get a big garage to do this work and no pressure to do all in a day
Post #141439 24th Apr 2012 7:19pm
