|  | Home > Td5 > Hazard light alarm? |
| foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64      | There is an inertia switch mounted on the bulhead just beside the coolant bottle. A large jolt causes it to trip turning on the hazards and according to the blurb should turn off the fuel pump though mine never has. It is supposed to be reset by pressing the rubber pad on the top of it. Although turning the ignition on and off does turn the flashers off the switch should still be reset manually. Land Rovers are an addiction. Toyotas are for quitters.
 WWW.CQLROC.ORG | ||
|  12th Aug 2009 4:16am |
| Ratty Member Since: 19 Mar 2009 Location: Somerset Posts: 37    | A hefty jolt to the alarm spider can also cause this. As the landy didn't cut out I would say that this is more likely in this case. | ||
|  12th Aug 2009 7:52am |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897      | Thanks chaps.
 Is it in the handbook, 'cos I can't find it? | ||
|  12th Aug 2009 12:12pm |
 If it's due to a faulty alarm spider it won't be in the handbook. It's more common with older Discoverys but I have come across it with the odd defender too. | ||
|  12th Aug 2009 3:23pm |
| Posting Rules
