![]() | Home > Maintenance & Modifications > 2007 Mantec Snorkel |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
You will need to drill 2 holes just above the air intake grille Andy
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 285 ![]() ![]() ![]() |
Thanks Andy, do you think drilling holes in the metalwork devalues the vehicle
![]() Carpathian 110 also sold Defender 110 camper now in build |
Maybe but when I sold my D3 I removed the snorkel and filled and painted over the holes. You couldn't tell anything had been there. Andy
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
When there's just a couple of holes left after removing a piece of kit I find it better to simply plug them with stainless steel, cup-head screws rather than try to cover them completely. Let's face it, it's a Defender with exposed rivets and everything so a couple of extra shiny screws won't make a difference. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
Good idea, maybe I would even paint the screws keswick green
Just got my Mantec kit today, the instructions are useless
![]() Most if it is fairly obvious but not sure about how to fix the mounting bracket to the windscreen pillar, the kit includes 10mm bolts which it claims are self-tapping, not sure though as they have blunt ends rather then pointed, guess it's a case of drill the hole and hope for the best ![]() |
I hate drilling painted surfaces
The bolts/screws do seft-tap in OK, just make sure you drill the correct size holes ![]() |
So are these a DIY job or do I need some special tool for the captive nuts that go in the wing above the vent?
You need a rivnut expander tool Andy
I will bring my rive nut tool to Yarwell we can fit them then. You drill the holes before you leave. ![]() |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 830 ![]() ![]() ![]() |
Fitted Mantec plastic Snorkel yesterday.
Handy fit - Thanks Andrew for details photos. ![]() I didn't have a Rivenut gun - But bolted it thru the wing instead. If you remove the plastic cover on top of the wing its easy enough get some lock nuts on. Its a good job that new snorkle, no vibration and does not obstruct your view thru windscreen as some others do. |
