Home > Puma (Tdci) > Best Snorkel
Page 1 of 6 123456>
jay knowles
Best Snorkel
As above been looking at the mantec model, any advice would be welcome thanks Jay
Post #140459 19th Apr 2012 10:20pm
I would stick to Mantec and Safari Only if I was you. Both are good. I would avoid the metal one's though. Thumbs Up
Post #140460 19th Apr 2012 10:24pm
RobKeay
I've fitted mantec flexi lite to my tdci's. Easy to fit if you have a riv nut tool. I didn't have one on my first snorkel so borrowed one from the dealer.
Post #140463 19th Apr 2012 10:38pm
jay knowles
Whats the induction noise like through the mantec, is it quieter than the standard set up, thanks Jay
Post #140466 19th Apr 2012 11:05pm
BigMike
no noise at all really.
Post #140468 19th Apr 2012 11:43pm
Zagato
What vehicle are you putting it on?
The Mantec one I believe is not a snorkel but a raised air intake used primarily to breath cleaner air higher up. The Safari Equip Snorkel can be used for wading if all sealed correctly, and with the TDCi you have to extend the breathers, TD5 maybe move the ECU etc....Other more knowledgeable members can expand on this ....I bought my Safari Equip one cos I love the look of them, it will never be used Whistle
I couldn't find any good close up pictures when trying to decide bteween elephants trunk or trilby! Can take some closer pics if you want Thumbs Up Other types are available of course....one that looks like a mushroom, one that looks like a salad mixing bowl etc Whistle All cool Cool
This one is on a Mantec RAI but has replaced the top cone for an ARB pre-filter (causes a cyclone):
Look here also Thumbs Up
http://www.defender2.net/forum/topic2105.h...p;start=45
Post #140486 20th Apr 2012 7:49am
I have the Mantec one at the rear of the picture above, it was on the vehicle when I bought it.
I like the looks of it and have no plans to replace. There is no induction noise that I have noticed. I have no plans to test it's efficency in water Very Happy
I have had Safari snorkels before and the build quality is excellent and they do what they say on the tin, however, if you are seriously wading I would suggest you buy the V8 version as the moulding is all one piece terminating in a tube that you then fit a hose too that leads to the air filter - this is the most 'sealed' version available - not sure about the Puma version but the TD5 / 300 version joins to the original hose set up at the wing and would be a LOT harder to seal effectively
V8:
300 / TD5
Post #140494 20th Apr 2012 9:04am
That last picture appears to be for the wrong side on a 300/TD5. IIRC it's the 200tdi that has the intake on the near side. Darren
Post #140500 20th Apr 2012 9:51am
They were generic pictures to give you an idea what I was talking about .....
Post #140503 20th Apr 2012 9:56am
leeds
On our Disco 2 TD5, Safari Snorkel, on our 300TDi 110 a Safari Snorkel, on our TD4 110 a Safari Snorkel.
All three of our vehicles do go wading as well
A properly fitted Safari Snorkel is Thumbs Up
You can fit a pre filter to a Safari Snorkel if going into dusty environs. However if you have a light bar fitted then it might impede onto the prefilter. However in Australia it is possible to get a filter 'sock' which fits into the top of the snorkel pipe
Yes you can say we are happy with Safari Snorkels Thumbs Up
Like a lot of good quality items with reputable names you get the copycat inferior products trying to trade off the original name. If you want to see how 'good' the copy cats are read the reports HERE
Brendan
Post #140504 20th Apr 2012 9:56am
There are also some very good copies on the market - a pal of mine supplies snorkels (but not Landy ones) and his are equally as well made as the genuine Safari ones .... www.aliensnorkels.co.uk
Post #140505 20th Apr 2012 9:59am
RobKeay
You can seal your mantec up also it's very similar to the oem raised air intake. There's alot yes induction noise but more wind noise at higher speeds.
Post #140506 20th Apr 2012 10:10am
leeds
Results of 4.5kg dart impact test on a genuine Safari Snorkel and two copies.
The structure of a non genuine snorkel
The structure of a genuine Safari snorkel
Please note that the Safari snorkel structure is finer and more uniform, and does not have the inclusions of the other one. This structure will give the Safari snorkel much improved mechanical properties, consistency etc.
Just because things look the same does not make them the same!
The above photos were lifted from the Safari Snorkel web site
Brendan
PS Edited to put right photo in
Post #140510 20th Apr 2012 10:41am
Happyoldgit
<Note> Steve.
http://forums.lr4x4.com
Post #140519 20th Apr 2012 12:09pm
They look the same Brendan Laughing
Safari all the way... QRZ 2e0vpf
Post #140520 20th Apr 2012 12:19pm
Page 1 of 6 123456>
