Home > For Sale & Wanted > Wanted - LR crossmember kit for bolt on tow hitch
bob neville
Hi
I am looking for the LR part KNK100090, the kit that allows you to bolt a hitch directly to the rear crossmember of a TD5.
I have a feeling it may no longer be available as Google has not come up with any answers apart from it is not available. Not tried the dealers yet.
I should be able to make the parts but would prefer the standard items.
Thanks
2013 Defender 90 CSW - sold
Post #139930 17th Apr 2012 8:34pm
wslr
Try Yeovil and ask them to look for the item within the dealer network, Bob. See what they come up with.
Post #139940 17th Apr 2012 9:02pm
bob neville
Thanks, I will give them a call Thumbs Up
Found one in the US, £35 plus £30 postage Shocked
Post #139941 17th Apr 2012 9:06pm
markb110
Bob
Will the replacement crossmember for your 90 not have the threaded inserts already included?
Assuming not as you are asking for the part
Mark
Post #139947 17th Apr 2012 9:21pm
bob neville
Hi Mark
Threaded inserts should be there. I am after the spreader plate that goes over the cross member and the angle iron that goes under the cross member. I could just bolt into the cross member but think it would be better to spread the load.
There are other options, 2" receiver the same as I have on the 110 or a Dixon Bates tow bar (202046).
As the 90 is not classed as a commercial (the 110 is) I think the receiver is out ( I will find the MOT tester who refuses to pass it !) so the DB route may be best, and it is cheaper than a receiver !
Post #139959 17th Apr 2012 9:43pm
I would have thought that a 2" receiver only becomes a towing attachment if you have a coupling fitted in it. I don't see how you could actually fail the MOT simply by having the receiver socket fitted, provided that you remove any coupling before the test. This doesn't of course alter the fact that it would be illegal to tow with it and you would also probably invalidate your insurance if they found out,
Also, don't forget that if you are being conscientious the coupling that you fit must also be type approved, so no NATO pintles.
I find it very hard to believe that this latest bit of Euromadness will actually make the roads safer! How many accidents in a year are caused by the failure of an inadequately designed towing hitch? Very, very few, I would wager.
Post #139993 17th Apr 2012 11:21pm
nakatanenga
Germany
E-approved NATO hitches are available for 339.-. EUR
KNK is available for 42.- EUR
Both on stock.
Hope that helps! WANTED:
SII or SIII in max 1.5k
Post #140027 18th Apr 2012 7:49am
bob neville
Thanks Peter Thumbs Up
Post #140030 18th Apr 2012 8:19am
bob neville
Got one, apparently the kit is still sold directly from LR Thumbs Up
Post #140052 18th Apr 2012 10:12am
