Home > Td5 > Is it possible to have an oil leak free TD5 ?
Page 2 of 2 <12
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Mine was leak free until the last service. I now have a leak under the main box. Could be from the engine as I've noticed a weep down the side of the rocker cover. Had a good wipe of the tray under the engine as I thought it was just spilt oil from the oil filter change but it's still leaking. Will look at the breather and give the underneath a clean when it go's up on the ramps to try and find it.
Post #136683 3rd Apr 2012 10:41pm
JWL
Just check the tightness of the oil filter, I had one that wouldn't stay done up and every couple of months or so would loosen off just enough to seep oil past Rolling Eyes When I do lift the bonnet to check the fluids it's become 2nd nature to lean over and check the oil filter.
Post #136690 3rd Apr 2012 10:57pm
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
Had a customer say to me recently
"the transfer box leaked from the day i got it and only stopped leaking a week before it blew up" Rolling with laughter Rolling with laughter
Paul Thumbs Up
Post #137472 6th Apr 2012 5:27pm
excossack
T/C seal has been changed by a garage this time and so far its OK, Oil filter is tight. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #137478 6th Apr 2012 5:50pm
excossack
Checked breather and all is clear.
Cleaned up the cam seal on the front of the engine and sealed with the same stuff they use on Puma sumps. 1999 Defender TD5 110
Regards
John M0VAZ
Post #137778 8th Apr 2012 10:25am
excossack
I think I have found the source of another leak, the oil pipe thats on the underside of the turbo. I found some oil at the flange joint with the turbo. Order new seal for that. 1999 Defender TD5 110
Regards
John M0VAZ
Post #138256 10th Apr 2012 12:44pm
excossack
Today replaced the turbo oil return feed pipe gasket. When I say replace, there wants a gasket there in the first place. Fingers crossed thats another leak fixed.
Next I think is the oil filter housing gasket, which I think is leaking and dripping down behind the engine mount 1999 Defender TD5 110
Regards
John M0VAZ
Post #139283 14th Apr 2012 9:11pm
yobbie
I think I've sorted mine today. I replaced the rocker cover gasket it looked like its been leaking at the back of the engine for a while.
Post #139293 14th Apr 2012 9:52pm
excossack
I replaced that one last year and i think its starting to weep slightly on the corner above the FPR 1999 Defender TD5 110
Regards
John M0VAZ
Post #139295 14th Apr 2012 9:55pm
excossack
Turbo oil return pipe leak fixed. I have just ordered rocker seal and front cam seal. 1999 Defender TD5 110
Regards
John M0VAZ
Post #139741 17th Apr 2012 8:48am
excossack
Front cam seal and rocker gasket replaced.Rocker bolts tightened to 10nm.
Lets see how long they last this time 1999 Defender TD5 110
Regards
John M0VAZ
Post #140739 21st Apr 2012 6:59pm
Page 2 of 2 <12
