Home > Td5 > Is it possible to have an oil leak free TD5 ?
excossack
Is it possible to have an oil leak TD5 ? So far I have:
Rear output seal on the transfercase (replaced seal twice)
Oil leak from around the oil filter area
Oil leak from the front cam seal(depsite changing this and using gasket sealant)
Slight weep from rocker gasket (again despite using a Genuine seal and gasket sealant and torquing to correct figure in correct sequence it still leaks. Time for a new seal again) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #136157 1st Apr 2012 8:58pm
Killer90
Site Sponsor
apart from leaky injector seals which are now sorted mine is pretty much leak free Thumbs Up fuel regulator is dripping a tad but not something to worry about just yet Very Happy
Post #136175 1st Apr 2012 10:41pm
Mine's as dry as a dry thing! QRZ M8VPF
Post #136179 1st Apr 2012 11:28pm
Laurie
So's mine Very Happy
Now, where's that bit of wood? Rolling Eyes
Post #136182 2nd Apr 2012 12:27am
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Mine, very slight weeps, nothing really - there are more pressing things in life for me to worry about 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #136185 2nd Apr 2012 6:16am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Have you checked your crankcase breather isn't blocked?
Post #136193 2nd Apr 2012 7:39am
Grockle
new in 05 36k when we sold it no leaks 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #136198 2nd Apr 2012 8:23am
excossack
I'm sure I have checked the breather - I will double check. 1999 Defender TD5 110
Regards
John M0VAZ
Post #136200 2nd Apr 2012 8:56am
MartinK
I had a TD5 Discovery. Owned from new for 187,000 miles in 9 years. Mostly road-use with some greenlanes (and a lot of travelling in heavy snow).
I only had 4 leaks.
2 x transfer box output shaft (can't remember whether front or back, I think they both failed once each).
1 x driver's side diff housing (rear)
1 x rear diff input seal
Other than that it was dry (well, dry enough not to spot the drive) throughout...
In all instances my Indie sorted them for a reasonable price when the vehicle was serviced... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #136215 2nd Apr 2012 10:29am
Zagato
Nobody posted the cliche about dry Landies yet Whistle
Post #136248 2nd Apr 2012 1:03pm
excossack
I hope its not too much to ask for 'a non oil leaking landy' nevermind the leak from the Alpine windows, which likes to drip on my knee, the leaking rear sliding windows. 1999 Defender TD5 110
Regards
John M0VAZ
Post #136250 2nd Apr 2012 1:12pm
changill
United Kingdom 2003 Defender 90 Td5 HT Bonatti Grey
Had the following leaks:
Tx Box Rear Output seal
Rear Diff Input seal.....twice
Engine front Camshaft seal
Clutch Master Cylinder
waiting for a leaky FPR.....and hoping not to get leaky injectors or a leaky head gasket Evil or Very Mad Only Alcohol Can Save me Now
Nanocom Available in the North West
Post #136358 2nd Apr 2012 8:22pm
excossack
I've had the leaky FPR and leaky cylinder - replaced with a new AMC one. Not a cheap job!
Front cam seal has been done twice 1999 Defender TD5 110
Regards
John M0VAZ
Post #136362 2nd Apr 2012 8:30pm
Gareth
Have you actually checked the oil level... Wink 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #136436 3rd Apr 2012 7:51am
excossack
I have and it does need a little bit of extra oil. I check the fluids once a week 1999 Defender TD5 110
Regards
John M0VAZ
Post #136442 3rd Apr 2012 8:11am
