Home > Maintenance & Modifications > Looking at Wheels |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 |
preditors? i don't think my "queer" wheels go down well in here
13th Feb 2008 6:47pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
I think the preditors are better than the Silverline.
Whats the spec on the Silverline The ZU's are rated to 1400 These may help you make your mind up Click image to enlarge Click image to enlarge |
13th Feb 2008 7:39pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
John
No contest, as far as i am concerned,, ZU's Not got a set, but a happy with the Mack 5's on the hybrid,,,very similar design but steel ! shame the offset is too high to run on the 07 !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
14th Feb 2008 10:24pm |
cairnsdisco Member Since: 30 Aug 2007 Location: Norwich Posts: 27 |
You cant run Mach 5's on the 07 defender????
15th Feb 2008 11:54am |
Is that a question,,?? or a Statement ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
15th Feb 2008 12:18pm |
question
15th Feb 2008 12:35pm |
I have 2 pairs of Mack 5's nether of which i have measured to find the offset etc,
They obviously fit to the hub, but due to a greater offset than standard, they would rub the arches both front and rear on articulation !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
15th Feb 2008 12:41pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Is that so? Is there a difference to TD5s then as I know people who run Zus on TD5 Defenders.
I'm begining to wonder if I should should just stick some better tyres on the standard Boost alloys. |
15th Feb 2008 3:07pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
I put a set of BFG MT`s 285-75-16 on the original boost alloys and sold the original tyres
15th Feb 2008 3:11pm |
John Can not see how their is any difference to TD5 !! The Zu's must have less offset, than my mack's, they look like they are less !! I think the pics above of AndrewS's 110 has had a suspension lift added, I when for another set of boost's with the popular 255/85x16 size BFG Mt's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
15th Feb 2008 3:42pm |
That may explain it - I know that Zus come in one offset that is 'within UK MOT regs' or some such wording.
IIRC one of the guys on here has them on his 90 with standard suspension and hasn't mentioned fouling. |
15th Feb 2008 5:03pm |
The Zu's will fit and are OK with standard suspension. We will be fitting 18" Mach 5's to our other 07 110
15th Feb 2008 5:29pm |
