![]() | Home > Maintenance & Modifications > Looking at Wheels |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 ![]() ![]() ![]() |
preditors?
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
I think the preditors are better than the Silverline.
Whats the spec on the Silverline ![]() These may help you make your mind up ![]() Click image to enlarge ![]() Click image to enlarge |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
John
No contest, as far as i am concerned,, ZU's Not got a set, but a happy with the Mack 5's on the hybrid,,,very similar design but steel ! shame the offset is too high to run on the 07 !! ![]() Main Brian James Trailer Dealer for South West UK |
cairnsdisco Member Since: 30 Aug 2007 Location: Norwich Posts: 27 ![]() ![]() ![]() |
You cant run Mach 5's on the 07 defender????
question
I have 2 pairs of Mack 5's nether of which i have measured to find the offset etc,
They obviously fit to the hub, but due to a greater offset than standard, they would rub the arches both front and rear on articulation !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Is that so? Is there a difference to TD5s then as I know people who run Zus on TD5 Defenders.
I'm begining to wonder if I should should just stick some better tyres on the standard Boost alloys. |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
I put a set of BFG MT`s 285-75-16 on the original boost alloys and sold the original tyres
John Can not see how their is any difference to TD5 !! The Zu's must have less offset, than my mack's, they look like they are less !! I think the pics above of AndrewS's 110 has had a suspension lift added, I when for another set of boost's with the popular 255/85x16 size BFG Mt's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
That may explain it - I know that Zus come in one offset that is 'within UK MOT regs' or some such wording.
IIRC one of the guys on here has them on his 90 with standard suspension and hasn't mentioned fouling. |
The Zu's will fit and are OK with standard suspension. We will be fitting 18" Mach 5's to our other 07 110
