![]() | Home > Maintenance & Modifications > Compressor Connection |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
I think he means 12 v conections
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
I think he does too. I was thinking along the lines of an Anderson connector?? Brendan has them for sale ![]() |
IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172 ![]() ![]() ![]() |
Thanks for the responses. Anderson connector looking as if it would do the business. Cigarette lighter socked definitely inadequate? Ian One wife - livid
As far as I am aware the cigarette socket is rated to 15amp maybe 20?. (Can't guarantee that) But some compressors can draw up to 30. ![]() |
Thanks and will check the rating. Otherwise Anderson . Ian One wife - livid
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2697 ![]() ![]() ![]() |
Hello Ian
I have the same compressor and use an Anderson connector that also has an inline fuse. I have the perminate connector positioned between the passenger seat and cubby box (90 HT) Mark |
I'd be interested in and Anderson connector too. Are they just loose the connector or can they be fixed in place? I'd be a bit worried about any shorting
Typical 12 volt sockets are rate at 16-20 amps Many 12v compressors are fused at 30-40 amps so do not really suitable for 12v sockets.
Small Anderson connectors are rated at 50 amps, standard one are rated at 175 amps. These are continuous rated but can carry much higher currents for short periods of time. They can be located on the front of the battery box like this. ![]() Doing it this way it is important to ensure cables going into the battery box is well grometted! Alternative is for Anderson connector to poke out of battery box like this ![]() Click image to enlarge If you use 175 amp Anderson connectors apart from compressor you can use jump leads, 12volt drills etc. Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Great info Brendan. It looks like the 175 would be best as it would be a one time job and also have other uses at the same time. Getting into the battery box is a pain too.
If we can help give us a shout. Have connectors, 35/50mm2 cable etc
Brendan |
Mobil Centre have a good selection too
![]() http://www.mobilecentre.co.uk/auxillary-po...6_179.html |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
This is what I was looking for... This is a straight connection to the battery, or has a any kind of relay/protection? Or goes through the fuse box ? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
