Home > Maintenance & Modifications > Compressor Connection
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Bought a twin cylinder T-Max compressor a few months ago. Excellent, but a pain having to remove the passenger seat base and battery cover to fit the croc clips every time I want to use it. Anyone aware of any simply (it has to be) fitted socket and plug to make the connection please? Vehicle a 110 Puma. I guess the cigarette lighter socket fusing wouldn't be adequate? Ian One wife - livid
Post #138489 11th Apr 2012 7:21pm
Laurie
Post #138490 11th Apr 2012 7:27pm
ibexman
I think he means 12 v conections
Post #138492 11th Apr 2012 7:29pm
I think he does too. I was thinking along the lines of an Anderson connector?? Brendan has them for sale Thumbs Up
Post #138495 11th Apr 2012 7:33pm
Post #138496 11th Apr 2012 7:34pm
IanW
Thanks for the responses. Anderson connector looking as if it would do the business. Cigarette lighter socked definitely inadequate? Ian One wife - livid
Post #138503 11th Apr 2012 7:45pm
As far as I am aware the cigarette socket is rated to 15amp maybe 20?. (Can't guarantee that) But some compressors can draw up to 30. Thumbs Up
Post #138507 11th Apr 2012 7:53pm
IanW
Thanks and will check the rating. Otherwise Anderson . Ian One wife - livid
Post #138524 11th Apr 2012 8:31pm
markb110
Hello Ian
I have the same compressor and use an Anderson connector that also has an inline fuse.
I have the perminate connector positioned between the passenger seat and cubby box (90 HT)
Mark
Post #138532 11th Apr 2012 8:42pm
I'd be interested in and Anderson connector too. Are they just loose the connector or can they be fixed in place? I'd be a bit worried about any shorting
Post #138551 11th Apr 2012 9:16pm
leeds
Typical 12 volt sockets are rate at 16-20 amps Many 12v compressors are fused at 30-40 amps so do not really suitable for 12v sockets.
Small Anderson connectors are rated at 50 amps, standard one are rated at 175 amps. These are continuous rated but can carry much higher currents for short periods of time.
They can be located on the front of the battery box like this.
Doing it this way it is important to ensure cables going into the battery box is well grometted!
Alternative is for Anderson connector to poke out of battery box like this
If you use 175 amp Anderson connectors apart from compressor you can use jump leads, 12volt drills etc.
Brendan
Post #138559 11th Apr 2012 9:33pm
Great info Brendan. It looks like the 175 would be best as it would be a one time job and also have other uses at the same time. Getting into the battery box is a pain too. Thumbs Up
Post #138594 11th Apr 2012 10:45pm
leeds
If we can help give us a shout. Have connectors, 35/50mm2 cable etc
Brendan
Post #138604 11th Apr 2012 10:59pm
Mobil Centre have a good selection too Thumbs Up
http://www.mobilecentre.co.uk/auxillary-po...6_179.html
Post #138626 12th Apr 2012 7:13am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
This is what I was looking for...
This is a straight connection to the battery, or has a any kind of relay/protection? Or goes through the fuse box ?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #138670 12th Apr 2012 10:14am
