![]() | Home > Maintenance & Modifications > ARB winch bumper with bullbar |
| totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
I fitted one on mine. it was build for protection for large kangaroo in Australia. the standard coils can support it. but, once you put in a winch it will droop i installed heavy duty coils from old man emu w nitrochargers. i got about an inch lift at the front. HTH
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
I may have a brand new 8274 version available shortly (once im back of hols) if you are interested ?
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
they do some great gear...but why is the german stuf soooo expensive?!
| Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236
Thanks but was just looking around, i usually take a few months to think things over before buying them. if that excited feeling you have inside dies down within a month or two then its not worth buying Now this has been on my list for over 6 months might actually get it now http://www.landrovertuning.com.au/shop/def...-seam.html 2012 Fuji White 110 Flattened |
Flattened
