Home > Maintenance & Modifications > QT diff guards
Page 2 of 5 <12345>
Lorryman100
The front one was simple enough, it was the rear one that was a bit of a pain due to the location of the mounting holes:
The red circled hole at the left side of the guard was the one I reamed. The other circled mount attaches to the diff pan mounting bolts and as you can see there is not a lot of room to get to it once the guard is positioned. But apart from that they are easy enough to fit and are a solid bit of kit. If you do fit them just check the clearance from the front sliding plate of the guard to the propshaft.
Post #137612 7th Apr 2012 11:49am
Thanks Brian much appreciated. The rear guard does look like it would have a good "sliding" effect to it. What I have currently is not really any different to standard IMHO
Post #137616 7th Apr 2012 12:00pm
MK
what is that yellow staining? looks like jarosite.... Puma 110" SW
Post #137636 7th Apr 2012 3:11pm
MK wrote:
what is that yellow stuff? looks like jarosite....
All guards are electroplated for corrosion resistance and full fitting instructions and bolt packs are supplied.
Post #137638 7th Apr 2012 3:14pm
discocuzzy
Make sure you really tighten up the bolts on the rear one, my diff started to leak as the thickness of the guard allowed the oil to creep up the threads.
Bit of brute force and they tightened up sufficiently. Thumbs Up You cannot teach stupid people to do clever things
Post #137723 7th Apr 2012 9:33pm
Thank-you for the tip these things are easy to not think of at the time aren't they Thumbs Up
Post #137727 7th Apr 2012 9:54pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Also worth mentioning is that the rear guards are different for 90s and 110s: it's a lot easier to fit one for a 90 than a 110. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #137728 7th Apr 2012 10:13pm
I'm happy with that Mr. Green They're probably cheapest to buy direct from QT I would imagine too. Thumbs Up
Post #137733 7th Apr 2012 10:29pm
BigRuss
Now I bought a set for my old disco, don't get me wrong that are indeed bullet proof. The front one fitted no problem but the rear on fauled the prop shaft, there customer service was crap and very unhelpful, I had a mate cut the end off and reeled it a but shorter and it fitted nicely.
The wife road tested the front slider that good I had to drag it of a mountain like rock Thumbs Up Russell
2011MY 110 XS USW Black
Post #137736 7th Apr 2012 11:03pm
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
They're probably cheapest to buy direct from QT I would imagine too. Thumbs Up[/quote]
http://www.qtservices.co.uk/parts/defender...-guar.html
not sure ive found the right ones?? but its the only ones for pumas on there Confused
Post #137844 8th Apr 2012 2:55pm
Harryb450
Or is it only the 110's that bolt to where the diff bolts in? Confused
Post #137870 8th Apr 2012 5:03pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
These are listed for Puma 110's
http://www.qtservices.co.uk/parts/defender...rd-pa.html 2002 Defender 110 DC
Post #137882 8th Apr 2012 6:05pm
Harryb450
so its only the 110 ones that bolt on where the diff bolts in Thumbs Up
Post #137883 8th Apr 2012 6:12pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I have mine to fit for a long time ...Bought straight from QT site...cheaper
But as the front ones need some welding, I have been delaying the job....Snigger ...I'm not able to do that and still waiting for a friend with the skills to come back from Angola!
And only very recently bought a set of decent tools to fit them...Maybe during this month I'll fit the back one...I'll post pics then too.... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #138014 9th Apr 2012 10:01am
They need welding why? Shocked
Post #138017 9th Apr 2012 10:22am
Page 2 of 5 <12345>
