![]() | Home > Maintenance & Modifications > QT diff guards |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Thanks Brian much appreciated. The rear guard does look like it would have a good "sliding" effect to it. What I have currently is not really any different to standard IMHO
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
what is that yellow staining? looks like jarosite.... Puma 110" SW
............................................................. Earth first. Other planets later Last edited by MK on 7th Apr 2012 3:16pm. Edited 1 time in total |
All guards are electroplated for corrosion resistance and full fitting instructions and bolt packs are supplied. |
| discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200
Make sure you really tighten up the bolts on the rear one, my diff started to leak as the thickness of the guard allowed the oil to creep up the threads.
Bit of brute force and they tightened up sufficiently. |
Thank-you for the tip these things are easy to not think of at the time aren't they |
| MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682
Also worth mentioning is that the rear guards are different for 90s and 110s: it's a lot easier to fit one for a 90 than a 110. Peter
2008 SWB Truck Cab 1952 80" Soft top |
I'm happy with that |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
Now I bought a set for my old disco, don't get me wrong that are indeed bullet proof. The front one fitted no problem but the rear on fauled the prop shaft, there customer service was crap and very unhelpful, I had a mate cut the end off and reeled it a but shorter and it fitted nicely.
The wife road tested the front slider that good I had to drag it of a mountain like rock 2011MY 110 XS USW Black |
| Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283
They're probably cheapest to buy direct from QT I would imagine too.
http://www.qtservices.co.uk/parts/defender...-guar.html not sure ive found the right ones?? but its the only ones for pumas on there |
Or is it only the 110's that bolt to where the diff bolts in?
| ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491
These are listed for Puma 110's
http://www.qtservices.co.uk/parts/defender...rd-pa.html 2002 Defender 110 DC |
so its only the 110 ones that bolt on where the diff bolts in |
| lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764
I have mine to fit for a long time ...Bought straight from QT site...cheaper
But as the front ones need some welding, I have been delaying the job.... And only very recently bought a set of decent tools to fit them...Maybe during this month I'll fit the back one...I'll post pics then too.... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
They need welding why? |
