![]() | Home > Technical > somke on start up |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979
Likewise. More noticeable in colder weather |
| mega Member Since: 23 Oct 2010 Location: notts Posts: 33
Thanks for the feed back everyone
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
@cradgebank Should be a little amount of oil the came from the turbo....(turbo side or compressor side) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406
mine does it, as did the last one, colder it is the worse it is, i wouldnt worry about it. Cheers
| Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610
The puma engine does run rich on initial cold start, and will produce a bit of smoke, especially when its really cold. It'll get worse when the EGR valve opens (3 seconds after engine start up) as it then breathes in this already rich mixture, causing even more smoke. The engine leans off quite quickly, once CHT start to climb, and so the smoke will clear.
