Home > Technical > somke on start up
Page 2 of 2 <12
pom wrote:
normal. Mine did the same.
Pom
Likewise. More noticeable in colder weather
Post #137424 6th Apr 2012 12:45pm
mega
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Thanks for the feed back everyone Wink
Post #137441 6th Apr 2012 3:27pm
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
cradgebank wrote:
The Musketeer wrote:
Blue = Fuel or Oil
Black = Oil
White = Water.
Sam, think you have that wrong, on a Diesel engine it should be
Blue = Oil
Black = Fuel
White = Water
Bloody hell your right Embarassed I was tired, only excuse! Good things come to the wild and free
Post #137469 6th Apr 2012 5:13pm
dgardel
Italy
Blue = Fuel or Oil
Black = Oil
White = Water.
Blue = Oil
Black = Fuel
White = Water
@cradgebank Thumbs Up Thumbs Up Thumbs Up
Should be a little amount of oil the came from the turbo....(turbo side or compressor side) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #137602 7th Apr 2012 10:31am
jst
mine does it, as did the last one, colder it is the worse it is, i wouldnt worry about it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #137712 7th Apr 2012 8:52pm
Alive Tuning
The puma engine does run rich on initial cold start, and will produce a bit of smoke, especially when its really cold. It'll get worse when the EGR valve opens (3 seconds after engine start up) as it then breathes in this already rich mixture, causing even more smoke. The engine leans off quite quickly, once CHT start to climb, and so the smoke will clear.
Post #137740 7th Apr 2012 11:48pm
Page 2 of 2 <12
