![]() | Home > Off Topic > Grumpy Old Man Thread |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
I think we should have a raised blood pressure thread after today's chasing my insurance claim.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Pulling an old carpet up.....
Then treading barefoot on the grippers |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Now that questions your position in the gene pool
No question, I know my place |
That'll teach you to wear steel toe-caps next time you do any work at home
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
ok so here goes ... this w/e's jobs ... nothing will get done because it will either be (1) too cold (2) rain (3) snow ...
I want to finish fuse box on 110, check door pillar/roof bolts and fit an accelerator cable to the 300/tdi .. if the weather is kind, I'll probably bash my knuckles and it will go pear shaped |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
I thought there was a Salibury Plain trip on this weekend but must have got the dates wrong and will have to work now anyway as I have spent to long doing up the boat
Took 2 days rubbing all the boat woodwork down and half way through putting 7 coats of oil/varnish on with 24 hr drying time in between - GRUMP!
But got my new wndows in
Just need to finish sorting the mess the previous owner made - some people should just not do DIY - GRUMP!
Trying to get her done in next two weeks for a trial sail for a five day sail/rally in May
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
Don't know much about boats but I'd fix that big hole in the back - it might help buoyancy perhaps ?
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
don't know too much about boats but that hole should be there, as you can see its been deliberately cut out and I can only assume its for ballast - is the bottom half of the hull the ballast tank?
na, it's to let the water out |
It started life as an outboard boat then an inboard was put in so the well hole was covered over. The last owner went back to an outboard so re-cut the well badly She is a well travelled boat used to sail from Scotland to France each year but I am planning to go over to the Isle of Wight for her maiden voyage... to test everything out! |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Hope it is more water tight than the vehicles you usually drive
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Mine's watertight - once the water gets in it can't get out... Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Boat chatter
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
