Home > Puma (Tdci) > Puma 2.2 Turbo Hose |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
Thanks for that
Not heard of it being a problem though even with the heavy towing lads Maybe just 2.2 related! |
2nd Apr 2012 12:39pm |
...and so it begins...
Looks like we'll have lots of new 2.2 members after all Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
2nd Apr 2012 12:58pm |
Could be wrong but have a feeling they repositioned the Turbo on the 2.2 to squeeze the DPF in! Why that would make any difference I don't know - useful eh! |
2nd Apr 2012 1:02pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Heat buildup causing the rubber pipe to go soft? 1999 Defender TD5 110
2nd Apr 2012 1:13pm |
Check your battery connectors as well (playing the Devil's advocate today)... Tell someone you love them today because life is short.
2nd Apr 2012 1:57pm |
Axel Member Since: 22 Jun 2011 Location: Bochum Posts: 107 |
Happened to me as well .... hose slipped off after approx. 1,500 miles .... has also happened to several other MY12 owners that I know ... Seems to be a kind of general bug ..... Best Regards,
Axel |
2nd Apr 2012 2:00pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
On 2009 builds as well, caught this in time.
Click image to enlarge |
2nd Apr 2012 2:36pm |
Doublecabdefender Member Since: 17 Jan 2008 Location: Norwich, Norfolk Posts: 61 |
Yup, that's the offending little chap 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
''I can resist everything except temptation. '' |
2nd Apr 2012 2:44pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
This seems a common problem on the 2.4 also. Someone at land Rover needs to ead his vegimite for breakfast.
Allan |
2nd Apr 2012 3:47pm |
... that's "Marmite" over here my Antipodean friend Tell someone you love them today because life is short.
2nd Apr 2012 3:59pm |
... but certainly either would do, together with a bit of brains mixed in (yeuch)
2nd Apr 2012 4:01pm |
Oh better keep an eye on it then Will be heavy towing soon
2nd Apr 2012 5:23pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4501 |
You could put some heavy duty duct tape on the hose beneath the hoseclip and then tighten the clip without damaging the hose. You could also repair the hose split temporarily with the duct tape. I've got stuff here called "Gorilla Tape" and it is really strong. 1982 88" 2.25 diesel
2nd Apr 2012 5:42pm |
The split is on the inside of the pipe, not the outside. I believe the pressure exerted on the pipe is immense when under load, tape might protect the external surface but I don't think that is the issue. I think its a poor design, LR gave me a call today and said they are trying to source a much wider jubilee clip which should almost fill the indent in the turbo outlet. Hopefully eliminating any form of slippage. 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
2nd Apr 2012 8:28pm |
