![]() | Home > Maintenance & Modifications > Defender 90 - Bike rack options? |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
Have a look at WarPig's excellent report here http://www.defender2.net/forum/topic11901.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Have you thought about a expedition rack. I have just got a patriot which I can carry bikes on. I will throw them on, but I expect you could get some nice holders for it, and you can climb up into it with a ladder so it's easy.
Loading stuff up without being on the roof can be a pain. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
We have one that hooks over spare wheel and rear door can still be opened even with bikes on (just)
we have a pendle .. have a look here
http://www.pendle-bike.co.uk/ |
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 ![]() ![]() |
I've got a 4 bike Maxxraxx on my 110. Can just lower it enough to open the door with the bikes still attatched. Very happy with it.
Wow just seen that they are £200 now. I paid £147 in October. Thats some price hike! ![]() semper in excretia sumus solim profundum variat |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 ![]() ![]() ![]() |
Thanks all for your help, the maxxraxx actually look a great option.
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Will a maxrax fit with a mantec rear wheel carrier, does anyone know?
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Can't say for sure. Measure how far your spare wheel protrudes and I will measure my maxxraxx and let you know.
![]() It fits around my safari equip tailgate type mount |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Tuf Rack plugged into the receiver is my favourite choice at the moment www.td5.org
Depends how many bikes you want to carry. If it's only two then I can recommend this one from Fabbri Gringo. Fits very securely to the spare wheel, is easy to load without messing about with bungees or similar and allows the back door to open fully.
![]() Click image to enlarge If you want to put them on the roof then the Thule 591 carrier is the weapon of choice. I had four mounted on roof bars and loaded them with an aluminium hop-up, as shown in the picture below. Even loading my relatively heavy electric bike was quite easy in this way. ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Jimb, 1 foot from top of tow hitch straight out to clear wheel carrier/wheel cover.
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 ![]() ![]() |
Mine from my old profile and defender... I had the ball mount removed and bars added which dropped into a plate mounted on the step bumper tow ball points. Why? So that wide bars did not smash the rear window! It also meant with one quick lift (having removed the pins) it was off... It also meant with bikes of the rear door would open.
I still have the rack but stupidly left the mount on expecting the purchaser to remove it and post it back... Oh we'll worked perfectly ![]() |
I will fit it tonight after work and take a picture with some measurements as well, as mine is mounted on an NAS step |
![]() Click image to enlarge ![]() Click image to enlarge The mounting plate sits 150mm away from the crossmember on the NAS ![]() Click image to enlarge Here you can see the measurements of my wheel, although probably irrelevant for you ![]() Click image to enlarge It sticks out 400mm from the crossmember, minus the 150mm of the rear step, so around a 350mm throw in total. ![]() Click image to enlarge I put a bungee around the bikes so they don't swing down onto the ground when you hinge the carrier down. You get great access to the back with the maxxraxx. Hope this helps Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
