Home > Maintenance & Modifications > Defender 90 - Bike rack options?
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I'm aware of the pendle and Thule tow-bar mounted bike racks, but wondered what experience you all have with bike options and a 90? I will nearly always have my two children in the back and therefore easy access to the rear door without having to take bikes off will be important, other option I assume is Thule roof bars and bike holders, but how easy is it to get the bikes up onto a Defender roof?
Any other good options out there?
Post #134453 26th Mar 2012 10:11am
MartinK
Have a look at WarPig's excellent report here http://www.defender2.net/forum/topic11901.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #134454 26th Mar 2012 10:13am
robpenrose
Have you thought about a expedition rack. I have just got a patriot which I can carry bikes on. I will throw them on, but I expect you could get some nice holders for it, and you can climb up into it with a ladder so it's easy.
Loading stuff up without being on the roof can be a pain. Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #134458 26th Mar 2012 10:30am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
We have one that hooks over spare wheel and rear door can still be opened even with bikes on (just)
Post #134559 26th Mar 2012 6:19pm
we have a pendle .. have a look here
http://www.pendle-bike.co.uk/
Post #134594 26th Mar 2012 8:02pm
richuk
I've got a 4 bike Maxxraxx on my 110. Can just lower it enough to open the door with the bikes still attatched. Very happy with it.
Wow just seen that they are £200 now. I paid £147 in October. Thats some price hike! Shocked Rich
semper in excretia sumus solim profundum variat
Post #134607 26th Mar 2012 8:37pm
mlightfoot
Thanks all for your help, the maxxraxx actually look a great option.
Post #134758 27th Mar 2012 11:43am
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Will a maxrax fit with a mantec rear wheel carrier, does anyone know?
Post #315745 13th Mar 2014 9:38pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Can't say for sure. Measure how far your spare wheel protrudes and I will measure my maxxraxx and let you know. Thumbs Up
It fits around my safari equip tailgate type mount
Post #315747 13th Mar 2014 9:50pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Tuf Rack plugged into the receiver is my favourite choice at the moment www.td5.org
Post #315756 13th Mar 2014 10:17pm
Depends how many bikes you want to carry. If it's only two then I can recommend this one from Fabbri Gringo. Fits very securely to the spare wheel, is easy to load without messing about with bungees or similar and allows the back door to open fully.
If you want to put them on the roof then the Thule 591 carrier is the weapon of choice. I had four mounted on roof bars and loaded them with an aluminium hop-up, as shown in the picture below. Even loading my relatively heavy electric bike was quite easy in this way.
 Darren
Post #315768 13th Mar 2014 10:35pm
david mitchell
Jimb, 1 foot from top of tow hitch straight out to clear wheel carrier/wheel cover.
Post #315777 13th Mar 2014 11:08pm
Matthew_Mills
Mine from my old profile and defender... I had the ball mount removed and bars added which dropped into a plate mounted on the step bumper tow ball points. Why? So that wide bars did not smash the rear window! It also meant with one quick lift (having removed the pins) it was off... It also meant with bikes of the rear door would open.
I still have the rack but stupidly left the mount on expecting the purchaser to remove it and post it back...
Oh we'll worked perfectly
Post #315808 14th Mar 2014 12:29am
Jimb1978
I will fit it tonight after work and take a picture with some measurements as well, as mine is mounted on an NAS step
Post #315835 14th Mar 2014 8:22am
Jimb1978
The mounting plate sits 150mm away from the crossmember on the NAS
Here you can see the measurements of my wheel, although probably irrelevant for you
It sticks out 400mm from the crossmember, minus the 150mm of the rear step, so around a 350mm throw in total.
I put a bungee around the bikes so they don't swing down onto the ground when you hinge the carrier down. You get great access to the back with the maxxraxx.
Hope this helps
Post #315966 14th Mar 2014 5:58pm
