![]() | Home > Puma (Tdci) > Erratic idle on start up. |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
Pressure fuel sensor, loosen speedo wires into the Gearbox/Tbox?
Mine had the latter problem. Puma 110" SW ............................................................. Earth first. Other planets later |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33
I had this problem and it was the EGR valve. It didn't log a fault code but the engineer thought the self-cleaning routine on engine switch off was noisy and that this was the likely problem. New valve was fitted and problem went. Self-clean routine almost silent compared to original one.
Hope this helps. Nick "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153
You know what, i've just realised I havn't been hearing the chucka-chucka noise for a while. Better let my dealer know eh? It should still do this even after a short journey, yes?
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Yes
I sent them an email...
For what it's worth, mine got noisier, not quiter? Best to get dealer to verify though... "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Is there any other way to identify it?
Had a chat with my service dept yesterday, basically they say unless there is an engine fault light showing there is nothing they can do, as warranty only covers failure, not failing. They also said its not unusual for the EGR to quieten down after a while when it beds in.
Does this sound right? |
When my new valve was fitted it was quiet doing the self-cleaning routine straight away. The old one was very noisy in comparison. This was replaced under warranty - no lights on the dash, and no fault codes, no problem with erratic revving once the new one was fitted... "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Do you know how it was considered a warranty issue then? |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
try to disconnect the electrical connector of the EGR valve (with ignition OFF).
If the erratic idle will go........... Ciao Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
I just complained about it and the dealer - Stratstone, Milton Keynes - replaced it, no hassle... "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Interesting. I must say I have noticed no change in performance, it still drives the same. Just the occasional erratic idle. It was fine today on the two occasions I used it so its intermittent whatever it is.
| All times are GMT |
