|  | Home > Puma (Tdci) > Erratic idle on start up. |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | Pressure fuel sensor, loosen speedo wires into the Gearbox/Tbox?
 Mine had the latter problem. Puma 110" SW ............................................................. Earth first. Other planets later | ||
|  3rd Mar 2012 7:49pm |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33      | I had this problem and it was the EGR valve. It didn't log a fault code but the engineer thought the self-cleaning routine on engine switch off was noisy and that this was the likely problem. New valve was fitted and problem went. Self-clean routine almost silent compared to original one.
 Hope this helps. Nick "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  19th Mar 2012 11:24pm |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153      | You know what, i've just realised I havn't been hearing the chucka-chucka noise for a while. Better let my dealer know eh? It should still do this even after a short journey, yes? | ||
|  20th Mar 2012 9:55am |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026    | Yes    | ||
|  20th Mar 2012 12:31pm |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153      | I sent them an email... | ||
|  20th Mar 2012 1:10pm |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33      | For what it's worth, mine got noisier, not quiter? Best to get dealer to verify though... "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  20th Mar 2012 11:52pm |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153      | Is there any other way to identify it? | ||
|  21st Mar 2012 10:07am |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153      | Had a chat with my service dept yesterday, basically they say unless there is an engine fault light showing there is nothing they can do, as warranty only covers failure, not failing. They also said its not unusual for the EGR to quieten down after a while when it beds in.
 Does this sound right? | ||
|  23rd Mar 2012 10:18am |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33      | When my new valve was fitted it was quiet doing the self-cleaning routine straight away. The old one was very noisy in comparison. This was replaced under warranty - no lights on the dash, and no fault codes, no problem with erratic revving once the new one was fitted... "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  23rd Mar 2012 8:39pm |
 Do you know how it was considered a warranty issue then? | ||
|  23rd Mar 2012 8:43pm |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    | try to disconnect the electrical connector of the EGR valve (with ignition OFF).
 If the erratic idle will go........... Ciao Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  23rd Mar 2012 10:33pm |
| Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33      | I just complained about it and the dealer - Stratstone, Milton Keynes - replaced it, no hassle... "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) | ||
|  24th Mar 2012 1:15am |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153      | Interesting. I must say I have noticed no change in performance, it still drives the same. Just the occasional erratic idle. It was fine today on the two occasions I used it so its intermittent whatever it is. | ||
|  24th Mar 2012 6:06pm |
| Posting Rules
