![]() | Home > Technical > Low Beam out |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
Hi guys i need your help. Im having problem w my steering column multi function switch assembly. While driving at night and when I hit a road bumps my LOW BEAM LIGHT GOES OFF. I just need to pull it a little bit maybe 1 mm and it lights up again. i need to hold it until I reach home.
![]() I tried to look for a replacement with part No. XPB 101290(models 2000 and up) but it only have a light assembly that have signals left and right, horn, high and low beam w flasher. But, what I have inside of my column assembly are with the wipers control, the switch for off,parking light and headlight. then the horn, signals and high and low beams w flasher. Am I buying the right replacement part? Thank you in advance. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Most likely it's the usual problem, ie the contacts in the dipswitch have overheated, softening the plastic of the switch and becoming loose or misaligned as a result. Replace the switch, item 7 in the picture. Either switch 7 or 8 can melt, but 7 melting seems more common.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
8 being sidelights and dipped lights control and 7 being main beam and also for some aux trigger too. Aswell as all the other obvious functions.
Yes exactly! I bought the switch and installed the number 8 number 6. And realighn the steering wheel and it works fine now ![]() thanks for the help guys! I really appreciate your help ![]() ![]() |
