Home > Td5 > wont start
reggielad
England 1999 Defender 90 Td5 HT Epsom Green
wont start
fitted new fuel pump bleed and now it ran for 10mins cut out then wont start again,tried bleed again and again no joy please hav you any ideas,someone said crankshaft sensor or has anyone had this prob before
Post #1334 8th Feb 2008 7:30pm
AndrewS
Have you gone through the correct bleed procedure. Question
Post #1340 9th Feb 2008 5:04am
j,moore
i had a simlar problem, did you clean out and change the fuel in the fuel tank. my td5 was brand new but had a problem where it would run ok for about five miles or so and then it would just cut out. land rover changed the fuel pump to no avail, and they put it down to dirty fuel, un convinced i took the fuel pump out and it looked ok but on closer inspection there was a film of cotton like fibres clogging the gause on the bottom of the pump. so i cleaned out the whole tank and pump, replaced whith new fuel and filter and it has been fine since. i recon land rover had not cleaned the tank when it was assembled new.
hope this helps, regards, jim.
Post #1348 10th Feb 2008 10:46pm
AndrewS
Turn ignition on press and release the accelerator 5 times. This tells the ecu to keep the pump running constantly. Normally the pump will stop pumping after 20 seconds. Leave the car with the pump running for a while. Eventually you will hear the pump sound change as the air is cleared from the system.
Post #1351 11th Feb 2008 10:41am
bell-auto-services
When you press the pedal 5 times it instructs the ecu to pump fuel for 45 seconds, you may need to repeat it a couple of times if you wish to bleed for longer than 45 seconds.
Regards Pete
Post #2205 28th May 2008 10:28pm
AndrewS
Shocked glad my old 110 didnt know that rule Razz
Post #2222 29th May 2008 7:46pm
Martin
Site Admin
From my old site: http://www.web-rover.co.uk/nav.php?p=td5kb/fuelpurge
My 1999 ECU runs the pump for 3 or 4 minutes, may have changed for later models Smile
Post #2223 29th May 2008 8:07pm
bell-auto-services
You must have a weird/edited ecu map then because inside the mapping stratgies there is this info set in stone unless changed by a tuner or LR special vehicles
only 2 different types 30 seconds and 45 seconds.
fp_cycle_times 6.0000 Times
fp_off_time 5.0000 Sec
fp_on_time 30.000 Sec
fp_pedal_presses_req 5.0000 presses
fp_pedal_prs_time 10.000 Sec
fp_prime_time 30.000 Sec
fp_prime_time 45.000 Sec
Regards pete
Post #2225 29th May 2008 8:30pm
Martin
Site Admin
Nope, brand new ECU off the shelf. MSB part number too, not NNN Wink
Post #2226 29th May 2008 8:41pm
bell-auto-services
Odd, i cant explane it then MSB183 is normaly 45 seconds acording to the software i see.
may be there is a odd version available that ive not seen in the past.
Do you still have this car now ?
Im looking at the Cruise options for the MSB owners that cant have in on there defenders without changing ecu's to the NNN flash type.
Post #2227 29th May 2008 8:44pm
Martin
Site Admin
Yep, still got it Smile
Post #2228 29th May 2008 8:52pm
AndrewS
The few I have bled ran for a few minutes Shocked
Post #2312 5th Jun 2008 5:12pm
