![]() | Home > Technical > Touch up pencil Kit |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Hi
Just received these touch up pencil kit, bought from our forum sponsor.... http://www.duckworthparts.co.uk/landrover/..._2007.html However, as I'm not a professional, and as the instructions are vague, need a little help Any one tried these ? (should have asked before I buy, I know! ![]() thanks Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
I use a toothpick to apply the paint as I find it a lot more accurate than those brushes they supply in the lid. Once dry, i then buff the resultant blob flat with 'Langka': http://www.langka.com/the-blob-eliminator-p-31.html
With a bit of practice, you can get an invisible repair ![]() Pete |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
Funny enough I just bought one today! Application tips are more than welcome. I have some marks on the bulkhead top and roof. Previous owner
Thanks guys!
![]() I'll try at the weekend...I'll let you know how it went! I'm going to get some thin brushes too... I have some huge (and some are deep) scratches along the side panels of my 110...start at the front and end at the rear! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
If you put too much paint in then once dry you can shave the excess off with a 'de nibber/razor'
http://www.frost.co.uk/automotive-paint/run-razor.html |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
If you have "huge,deep scratches" depending on how bad/wide they are you may have to etch prime first!
They're huge, because they're long...and deep, but very thin...I dont think that will be necessary to etch prime...I hope!
As long as it's only down to the vehicle primer I think you'll be okay. Down to bare metal though that's different. |
Should be ok then ![]() Ah gone are the days when you could just rub them out with T Cut paint was so thick. SAAB paint used to be as thick as the LR metal is - seriously, 20 coats of it. |
How much did the paint alone weigh then? ![]() ![]() |
A doubter
![]() ![]() ![]() SAAB's 96's,99's were not light, they were a lot heavier than an Escort, Beetle, etc you couldn't push the roof in for instance, I think it was the Japs that brought in tinny motors, they certainly had the reputation for it ![]() |
Zag, If you think the Defender paint is thin you should try a Navara's couple of years ago scratched it by opening door against a hedge. Parked of course and not buckthorn just a regular hedge.
Crap quality as these days as well, bird poo left on the roof the night before can be found on the floor the next morning whilst adding two holes to your motor
