Home > Technical > Drive without rear driveshaft |
rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46 |
My second trip in my new 110 (four years old, 2008) was from Paris to Nice. I am in the process of moving so the truck was full of furnitures. After 300 problem free kilometres (at 120 km/h) a high smack and violent vibrations occurred. I immediately clutch out and gently applied breaks. On the hard shoulder I discovered that the rear driveshaft rear connection (flanged yoke was broke) I disconnected the driveshaft and continued the trip with the difflock engaged.
At low speed (below 60 km/h) there was some noisy rattling sounds from what I think was the handbreak drum. (Like it was shacking back and forth) Also in gear change. But on constant speed above 60 km/h the car was behaving “normal”. Now: Have I damaged something? Is it perfect OK to drive on only the front driveshaft. I drove about 700 km! Is that a record or just is business as usual? What should I check after fitting a new connection? Should I change the whole driveshaft or only the yoke connection? Is there anyone who have an in-depth understanding of the inner parts in the hand break drum and/or transfer gearbox that believe I have damaged anything? By the way, is it easy to fit a new driveshaft? And at last: How can this happened with such a “new” car? |
17th Mar 2012 8:15pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6050 |
If ever i've blown a rear diff or halfshaft (quite regularly when I first got a 90, and couldn't afford luxurys like 4 pinion diffs or ARBs) we'd just remove the rear shaft, BUT..... put the 4 nuts back onto the handbrake drum studs.... you'll need to space them out slightly (just 4 slightly larger nuts will do, or a handfull of washers) to make sure that they pull up tight.
18th Mar 2012 9:24am |
Thank you very much for your replies! Highly appreciated!
I would like to upload a picture of the broken part. Is that possible to do here? Finding the correct part. For my Defender 110 (1986 model) I had a complete parts catalogue. I cannot find that for the Defender Puma? What is the solution? How are you identify the correct part number? Cheers, |
18th Mar 2012 11:16am |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 |
part numbers here http://www.defender2.net/forum/topic5282.html
Cheers Puma 110 |
18th Mar 2012 12:53pm |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
From researching a new prop shaft for my 110 I came to the conclusion that the rear prop from a PUMA is identical to the rear prop from a defender 110 with disk braked rear salisbury axle. Both are 111cm and have all the same bolt holes. Might help you to find one more cheaply. Keep an eye on Ebay though. I just bought a brand new genuine Puma 110 rear prop for £52....
18th Mar 2012 1:39pm |
Would be interesting to know if your propshaft had grease nipples or not (0, 2 or 3)
Some went out of the factory with missing nipples, some props were "greased for life" and had no nipples and some had the regular 3 nipples (also interesting "Nipples" is not censored) |
18th Mar 2012 1:48pm |
Fnaar fnaar..... |
18th Mar 2012 2:30pm |
One of my friends have a brand new propshaft. Part number is FRC8389. Is that the one that can be used for my 110 Puma Cheers, |
20th Mar 2012 9:16pm |
front propshafts have not changed since 300tdi but rear props have - you'll need to check
20th Mar 2012 10:15pm |
Puma 110 rear propshaft is part number LR010463 (110cm long)
The 300 tdi one which should also fit is FTC3905 (110cm long) FRC8389 is a 200 tdi one and is too short (101 cm long) |
20th Mar 2012 11:05pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
If the vehicle's out of warranty (assume it is!), the what about one of these:
http://www.gwynlewis4x4.co.uk/page36.html I had been looking at these to replace the front prop shaft on my Discovery 2 (because of the double-cardon issues). The company does supply the whole lot (incl the "specal" bolts). They look the business! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
23rd Mar 2012 7:45am |
Thank you very much for all your replies!
I have ordered the LR010463 propshaft from paddocks. By the way (another stupid question ) why is the manual mention: “2. NOTE: Mark the rear driveshaft to parking brake flange.” And “3. NOTE: Mark the rear driveshaft to rear differential flange.” ? When I removed the driveshaft, while on the hard shoulder, I did not mark the shafts connections. Is this an issue? I presume that the miss alignment or rotational orientation of the two flanges (called phased in the manual) is correct when I receive driveshaft? In other words how do I insure that I have the correct phase or correct aligned when I fit it on? Thank you very much in anticipation. |
23rd Mar 2012 11:21am |
Don't worry about it. Your new prop shaft will only fit in 2 positions, either will be fine. The phase issues are only important if you pull the 2 halves apart. It may be that the original prop was dynamically balanced on the vehicle which is why the book suggests it goes back on in exactly the same place but since you are replacing it then I cannot see that it will be an issue. The new prop "should" be correctly phased and balanced out of the box.
23rd Mar 2012 1:06pm |
Thank you for your answer, which align with what I was presuming. (I just want to be sure ) Cheers, |
23rd Mar 2012 1:40pm |
