![]() | Home > Puma (Tdci) > who does and who doesn't use 1st gear? |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Always use first gear.I keep pressure on the gear stick to keep it to the left and get a smooth change in to second gear. 1982 88" 2.25 diesel
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
spudfan (and all)
thanks, I'll try keeping pressure to the left for a smooth change. Up til now its either been a very slow change (almost like double clutching) or a slightly less than smooth change. |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
1st gear. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
I used to use 2nd in my TD5 but always use 1st in the TDCi. Think TDCi has lower first gear than TD5 so that makes no sense
If you pull away on a very steep hill and take the usual time to change from 1st to 2nd look in your mirror and watch the car behind have to slow down before they run in the back of you |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21039
Maybe they won't be so close next time |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
this is part of the issue of running a utility vehicle that's capable of towing 3500kg as a daily / unladen drive.
2 nd's a tad to high but if you pull away with slip on the flat or slightly down hill its great, trying to get a flyer in a defenders wrong! 1st with higher tyres would be spot on i'm guessing. with a caravan / car trailer / plant trailer etc the lowish first makes perfect sense, great for maneuvering and just list the clutch with no throttle and away you go. You need to try drivin all day in low box like we did in Wales recently 3rd Low was low! 4-5-6 geting you up to 20 mph |
Clutch slipping = clutch wear and reduced life. Done on a regular basis won't last long I doubt
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153
I always use first gear in my 110, unless I'm on a downhill but even then I find 2nd a touch too high. Thats with 235 tyres. I wonder if those who pull away in 2nd are in 90s with 205s on?
do they still do 205's on a puma?
| defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411
i will only use second if I'm on a down incline. I'm uncomfortable about not using first. I was taught to always use all the gears going up or down through the box.
I was taught to jump gears but I don't in the Defender it's risky and to be honest there often isn't point. I prefer to go through the gears. |
Sure, you still see farmers 90s on 205s. |
| NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397
Never used 2nd to start away, always do 1st to get in motion. Never forget: cars have owner, Landrover have field service personnel.
| All times are GMT |
