![]() | Home > Puma (Tdci) > What Coolant Liquid |
rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46 ![]() ![]() |
I have just, in a moment of total madness, bought a 110 SW E 2.4TD from 2008. (55900 km)
So fare I have only been driving it from the dealer to my home – 12.5 km The level in the coolant reservoir is not at the mark it should be (Cold) (The car come from Madrid where it is very hot during the summer) 1) How can I identify the used cooling liquid? 2) Can I top up with water? 3) Is the Havoline Texaco XLC the right one for the Puma? Thank you very much in anticipation! ![]() |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Should be OAT type coolant, which is orange in colour.
You can top it up with water, but ideally you should be adding a 1:1 mix of water and OAT coolant. And yes, the official coolant is the Havoline/Texaco XLC. |
Thank very much for the quick reply
![]() BTW. What is OAT actually stand for? Cheers, |
Organic Acid Technology
do you mean OEM ? - Original Equipment Manufacturer
Shhhhhhh!! ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
I use this: http://www.opieoils.co.uk/p-903-motul-inug...reeze.aspx I found that it's pretty much as close to what is standard use. Also forum discount too.
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
at a LR dealer the part number for the correct coolant is STC50529.
Don't mix OAT antifreeze with the standard stuff you'd get in a garage as I have been told it turns to porridge ! |
Sounds about right to me ![]() |
