|  | Home > Puma (Tdci) > What Coolant Liquid |
| rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46    |
 I have just, in a moment of total madness, bought a 110 SW E 2.4TD from 2008. (55900 km)
 So fare I have only been driving it from the dealer to my home – 12.5 km The level in the coolant reservoir is not at the mark it should be (Cold) (The car come from Madrid where it is very hot during the summer) 1) How can I identify the used cooling liquid? 2) Can I top up with water? 3) Is the Havoline Texaco XLC the right one for the Puma? Thank you very much in anticipation!  | ||
|  14th Mar 2012 9:54am |
| wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581    | Should be OAT type coolant, which is orange in colour.
 You can top it up with water, but ideally you should be adding a 1:1 mix of water and OAT coolant. And yes, the official coolant is the Havoline/Texaco XLC. | ||
|  14th Mar 2012 11:57am |
| rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46    | Thank very much for the quick reply    BTW. What is OAT actually stand for? Cheers, | ||
|  14th Mar 2012 12:42pm |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897      | Organic Acid Technology   | ||
|  14th Mar 2012 12:54pm |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | do you mean OEM ?  - Original Equipment Manufacturer | ||
|  14th Mar 2012 1:03pm |
 Shhhhhhh!!  | ||
|  14th Mar 2012 2:37pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | I use this: http://www.opieoils.co.uk/p-903-motul-inug...reeze.aspx I found that it's pretty much as close to what is standard use. Also forum discount too.    | ||
|  14th Mar 2012 3:52pm |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297      | at a LR dealer the part number for the correct coolant is STC50529.
 Don't mix OAT antifreeze with the standard stuff you'd get in a garage as I have been told it turns to porridge ! | ||
|  14th Mar 2012 4:40pm |
 Sounds about right to me  | ||
|  14th Mar 2012 5:54pm |
| Posting Rules
