![]() | Home > Maintenance & Modifications > Spinning rivnut solution? |
Theres a sticky on here about how to fab a DIY Rivnut tool
A small amount of glue might help but why not try just tightening up the rivnuts. No need for a special tool for three of. Just have a read HERE
Brendan |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2033 ![]() ![]() |
I finally bought a Rivnut tool from eBay, was £13 and works a treat. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 ![]() ![]() ![]() |
hexagon rivnuts is what i use to stop this ever being an issue, they can be used to great affect on a round hole if you drill it slightly smaller than needed (about 0.75mm smaller) and then tap in gently with a small hammer before crimping.
Nathan.k Member Since: 21 Aug 2011 Location: Cheshire Posts: 9 ![]() ![]() ![]() |
You can get a new type of rivnut now called a rawlnut which is a rubber rivnut, it will expand to any shape hole and is reusable. All my light guard rivnuts where spinning. It was a nightmare to drill them out, bit of grease this time on the screws and the new rubber rivets has worked a treat! Couldn't recomend them enough!!
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
I brought one of these along with a couple of boxes of the alu rivet nuts but when they arrived there supplier had sent steel ones so rang to say needed alu ones to stop reaction between body work and nut and they sent replacement alu ones and said keep others as cost of sending back wasn't worth it
Brilliant bit of kit don't know how I have survived without one all these years ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
