![]() | Home > Puma (Tdci) > Leeky Floor |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 266 ![]() ![]() |
Hi All
any of you fellow puma owners had an issue with a leeky floor? and if you have, how did you stop it? have lifted the floor mats, and there is a bolt in panel, as oppose to solid floor pan (not sure if this is the norm, this being my first diffy) suggestions welcome. Cheers keith puer claudius |
Keith
Land Rover use 'Dum Dum' when they try to stop leaks according to the 'leak guide'. I have just purchased some from Frost Restoration. Bob |
hi guys
thanks for the replies. will give morrisons a call first, and see what they can do for me. failing that, i think i will order a bug tub of dum dum and seal up everthing.... Cheers keith puer claudius |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
I had a similar problem last year, only with having rubber mats did not notice wet footwells underneath. Had loads of heavy condensation overnight over the winter which highlighted the severity of the problem. Dealer had to remove the dash to trace it and found water leaking in quite badly though the heater/bulkhead joint area. Footwells bone dry since it was sealed. Have had the usual problem of a few water drops sitting on the rubber mats on both sides when left stationary in wet weather. Comes in from behind the dash somewhere. Have tried by a process of elimination to locate the source. As a last resort I temporarily taped the joint between the bonnet hinge bracket and the bulkhead about a month ago and, (touch wood), the leak has not appeared again despite many heavy downpours. Will get dealer to seal this joint on next visit.
Could the leak be down to the auto box swop people ? 2.4 90 XS
Grockle
thought that, but found something inteesting on the way to wok this moning, after drying out the floor on tuesday, not that it was that wet, and driving though lots of puddles on way tot work this moning, still have a dry floor, my wife has suggested that it may be because i wash the car out with soapy water, and do not dry it! she mau have a pint, so i will monitor on the way home and see what happens. Cheers keith puer claudius Last edited by kljw on 17th Jul 2009 12:31pm. Edited 1 time in total |
Morning Keith,on our previous Defender it leaked like a sieve,after many many visits to the dealer,driving around with the dash out, bulkhead covered in chalk dust it turned out to be the windscreen seal,worth a look. 2.4 90 XS
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Took mine in: water on the rubber mats and dripping off the heater matrix. It was the windscreen seal.
Replaced and no issues since. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
When mine went in for the old water in the passenger footwell, I was told that in my case it was a faulty joint on the washer jet cable
![]() Richard 1963 Series 2A truck cab 2008 110 SW |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
My passenger footwell leak still nor solved
![]() In fact in getting worse ![]() ![]() Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Hi Ed,have you had the door seal changed ?,silicon sealer may sort the roof seam leak
![]() 1968 1/32 scale Britains 109 Pick up. |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
Hi Eduardo, I have a copy of the Landrover "Water ingress Manual" in PDF do you want it? My td5 dripped on the drivers floor, was coming from the back door and "rolling" forward inside the roof and dripping down, sealed the back rivets on the back panel again where they joined the roof and it stopped Last edited by sasha2001 on 20th Jul 2009 8:11am. Edited 1 time in total |
Door seal has been repaired (not changed as I can see) twice without success
![]() ![]() Sasha, I have the manual, thanks, but regretably I dont have the time rigth now to do it by myself (toooo much work in the company ![]() Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
