Home > Puma (Tdci) > Leeky Floor
kljw
Leeky Floor
Hi All
any of you fellow puma owners had an issue with a leeky floor? and if you have, how did you stop it? have lifted the floor mats, and there is a bolt in panel, as oppose to solid floor pan (not sure if this is the norm, this being my first diffy)
suggestions welcome. Cheers
keith
puer claudius
Post #13026 16th Jul 2009 10:56am
RED-DOT
Hi Keith.. i had 8 leaks on my 90 XS and i called John Sinton at your supplier (Morrisons) and after two goes they got them all with a bit of silicon in the correct areas.... He is the bodyshop manager and he has some unique explanations as to why our Defenders fail in so many ways.. e.g, he said Defenders should never have been made with carpets as this shows up the leaks!!
Post #13032 16th Jul 2009 12:02pm
bob neville
Keith
Land Rover use 'Dum Dum' when they try to stop leaks according to the 'leak guide'.
I have just purchased some from Frost Restoration.
Bob
Post #13033 16th Jul 2009 12:13pm
kljw
leeky floor
hi guys
thanks for the replies. will give morrisons a call first, and see what they can do for me. failing that, i think i will order a bug tub of dum dum and seal up everthing.... Cheers
keith
puer claudius
Post #13034 16th Jul 2009 1:42pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I had a similar problem last year, only with having rubber mats did not notice wet footwells underneath. Had loads of heavy condensation overnight over the winter which highlighted the severity of the problem. Dealer had to remove the dash to trace it and found water leaking in quite badly though the heater/bulkhead joint area. Footwells bone dry since it was sealed. Have had the usual problem of a few water drops sitting on the rubber mats on both sides when left stationary in wet weather. Comes in from behind the dash somewhere. Have tried by a process of elimination to locate the source. As a last resort I temporarily taped the joint between the bonnet hinge bracket and the bulkhead about a month ago and, (touch wood), the leak has not appeared again despite many heavy downpours. Will get dealer to seal this joint on next visit.
Post #13035 16th Jul 2009 3:12pm
Grockle
Could the leak be down to the auto box swop people ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13047 17th Jul 2009 8:09am
kljw
Grockle
thought that, but found something inteesting on the way to wok this moning, after drying out the floor on tuesday, not that it was that wet, and driving though lots of puddles on way tot work this moning, still have a dry floor, my wife has suggested that it may be because i wash the car out with soapy water, and do not dry it! she mau have a pint, so i will monitor on the way home and see what happens. Cheers
keith
puer claudius
Post #13049 17th Jul 2009 8:42am
Grockle
Morning Keith,on our previous Defender it leaked like a sieve,after many many visits to the dealer,driving around with the dash out, bulkhead covered in chalk dust it turned out to be the windscreen seal,worth a look. 2.4 90 XS
Post #13050 17th Jul 2009 9:32am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Took mine in: water on the rubber mats and dripping off the heater matrix. It was the windscreen seal.
Replaced and no issues since. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #13054 17th Jul 2009 10:35am
YORKSHIRELAD
When mine went in for the old water in the passenger footwell, I was told that in my case it was a faulty joint on the washer jet cable Confused . Whatever they did it is much better but I still get a few drops after a good downpour but I can live with that for now. Cheers,
Richard 1963 Series 2A truck cab
2008 110 SW
Post #13066 17th Jul 2009 8:00pm
Eduardo
My passenger footwell leak still nor solved Evil or Very Mad
In fact in getting worse Sad Sad . I can see drops getting from the joint of the roof and the door seal. I will post some pictures after the next rain (Monday to Tuesday)
Cheers Eduardo
Post #13072 17th Jul 2009 11:24pm
Grockle
Hi Ed,have you had the door seal changed ?,silicon sealer may sort the roof seam leak Thumbs Up 2.4 90 XS
Post #13088 19th Jul 2009 9:20am
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Hi Eduardo, I have a copy of the Landrover "Water ingress Manual" in PDF do you want it?
My td5 dripped on the drivers floor, was coming from the back door and "rolling" forward inside the roof and dripping down, sealed the back rivets on the back panel again where they joined the roof and it stopped
Post #13102 19th Jul 2009 8:38pm
Eduardo
Door seal has been repaired (not changed as I can see) twice without success Sad Sad
Sasha, I have the manual, thanks, but regretably I dont have the time rigth now to do it by myself (toooo much work in the company Sad ) Also the Defender is rigth now doing her duties in the forest so I will not have access to her until next week. Anyway, will be raining tomorrow, so I request some pictures to my son to show them to the stealers.
Cheers Eduardo
Post #13105 20th Jul 2009 4:39am
