Home > Maintenance & Modifications > Fitting Entreq 110 reinforcement mudflap brackets
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi,
I'm going to fit these tomorow. i asume dry fit 1st, mark holes, drill. coat new holes with supplied paste, gasket each side of wing, fit bracket and tighten? Am I forgeting anthing??
regards Myn. Cool Smoke me a kipper I'll be back for breakfast.
Post #130351 10th Mar 2012 7:11pm
BigRuss
That's about it Thumbs Up
You may have a few issues if the mud flaps have already twisted the metal. Russell
2011MY 110 XS USW Black
Post #130355 10th Mar 2012 7:16pm
Mynstral
Hi, BigRuss
Not as yet, thought i'd fit them before they did, belt and braces.
regards Myn. Smoke me a kipper I'll be back for breakfast.
Post #130359 10th Mar 2012 7:19pm
BigRuss
Yeah it's worth it, my last defender never had the problem for the 4 years I owned it but my puma didn't last 12 months Big Cry before the first broke and then the other one wasn't gonna be far behinded so luckily I fitted the brackets. Thumbs Up Russell
Post #130363 10th Mar 2012 7:23pm
leeds
Clean all mud off area first. Otherwise you are likely to be removing it from eyes, nose, mouth as you drill the bottom of panel/fit them.
Brendan
Post #130365 10th Mar 2012 7:23pm
Mynstral
[quote="leeds"]Clean all mud off area first. Otherwise you are likely to be removing it from eyes, nose, mouth as you drill the bottom of panel/fit them.
Brendan[/quote
Thanks for the advice Brendan.
Post #130366 10th Mar 2012 7:26pm
Brendan
hey Brendan - have you been on that course ?
Post #130386 10th Mar 2012 8:10pm
leeds
Steve, as you get use to me you will find out I spend more time going off course rather then going on courses including that course!
i get bored on courses and go off and do my own variations! Thumbs Up
Brendan
Post #130395 10th Mar 2012 8:59pm
MK
Any reason rear mudflapd can not be fitted at the very rear hanging from the chassis? NO matter how many reinforcement you add, the OE assembly will twist anyway. Puma 110" SW
Post #130422 10th Mar 2012 10:22pm
Zagato
I think you would have to fabricate quite an involved strong framework to hang the mudflap bracket on if the rear quarter panel didn't come into use! Unfortunately the panel is the only really practical point in which to attach the bracket to.
As far as I see it the twisting is from front to back as the mudflap is wagged back and forth particularly with motorway driving. What a 2" say homemade or Entreg bracket does is prevent that force twisting the metal off as it overlaps the lip from front to back.. If the force was in the other direction i.e. sideways then yes the bracket wouldn't work but it isn't.
I didin't even bother drilling the other two holes as they are not necessary if you still have your original hole intact, the force isn't that way, less holes the better Wink The old Series used to have bracket coming out fixed to the same bottom lip point on the rear panel to stop the panel flapping/gendering in the wind. This fixing point on my 1968 Series model had enlarged where the bolt had passed through the lip but it was still doing it's job Very Happy
Post #130449 11th Mar 2012 7:57am
i guess the other option is to use less stiff material for the mud flaps
Post #130452 11th Mar 2012 8:33am
ericvv
Zagato, interesting comments about not drilling the other two holes. I just ordered the reinforcements from Entreq and as everything is still fully intact with me, I will try to go that way. Thanks Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #130453 11th Mar 2012 8:36am
lrMike
Greece
Nice point there!!
Are you aware of any less stiff mudflap product that we could use to avoid this problem?
Mike.
Post #130474 11th Mar 2012 11:07am
Happyoldgit
A bit like 90's and Series models which are bolted to the rear x member. Steve.
http://forums.lr4x4.com
Post #130547 11th Mar 2012 6:50pm
Happyoldgit
lrMike wrote:
Nice point there!!
Mike.
For years people have been cutting mud flaps out of conveyor belt rubber which can be got in various thicknesses. Steve.
Post #130548 11th Mar 2012 6:52pm
