Home > Maintenance & Modifications > Fitting Entreq 110 reinforcement mudflap brackets
Page 2 of 2 <12
MK wrote:
Any reason rear mudflapd can not be fitted at the very rear hanging from the chassis? NO matter how many reinforcement you add, the OE assembly will twist anyway.
The problem with fitting them on the rear crossmember on a 110 is that they're so far away from the wheels that they don't work. That's probably why they were moved forward in the first place.
I've got to wonder whether Land Rover have done something to the wing material on later vehicles - either the material composition or thickness. I recently removed and re-fitted the rear mudflaps on my nearly 7 year old 110 and there's no sign of any problem with the wing. I don't remember it being an issue on my 1982 Stage 1 either Confused Darren
Post #130553 11th Mar 2012 7:01pm
ericvv
Don't think it is all that bad on recent models. My SVX is 3.5 years old, has 56.000KM of which 1/3 on highway at 120km/hr speeds. And no sign of damage whatsoever. I will put the Entreq reinforcements just as a precaution now, but wonder if the damage that many of us are speaking of is not more related to rough usage, off-roading, etc. Question You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #130579 11th Mar 2012 8:27pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Does anyone manufacture a really stiff bracket or tube bolted only to the chassis rails from which to hang the mud flaps?
1" tube fillet welded to a 3 point fixing boss perhaps?
Or a pair of lightweight alloy triangular brackets bolted/rivetted to the underside of the wheel box to mount the mud flaps to?
And what about a simple swinging/hinge mechanism for the flap itself for off-roading?
(Mine's just fallen off!)
Post #130604 11th Mar 2012 9:05pm
MK
Would be a legal issue by moving the flaps further back? I would not like to throw stones and chips to the cars behind (if any).
Also in 90"īs the mud and stones should hit the inside of the back panel and lights Question Puma 110" SW
Post #130665 12th Mar 2012 1:20am
ericvv
Mea Culpa, Mea Culpa Bow down I have to swallow my own words "no sign of damage whatsoever" Big Cry
I went to fitting the Entreq mudflap reinforcements today, left side first, which indeed was as I said, not the slightest sign of damage, bended aluminium or whatever. So fitting the reinforcement was a straightforward precautionary job, and I did not bother to drill the 2 new holes as Zag has suggested.
Then to my surprise, the right side was an outright mess, underside bended and sheared metal, but with the mudflap bracket still in place. Took me a while to put everything in shape again, then repainted a few tiny damaged spots, with a bit more difficulty installed the Entreq reinforcement, but obviously this side I had to drill the 2 extra holes. Sad
Not sure what this is all about, the left side is as new as ex factory, the right side pretty bad. Why this difference, have no idea. Question Question Question And that on a truck which is treated gently all the time. Beats me, but happy it got sorted now, further damage should hopefully be prevented. You never actually own a Defender. You merely look after it for the next generation.
Post #138772 12th Apr 2012 6:55pm
kmac
Finally got round to installing my Entreq mud flap brace - just as well as one side was beginning to deteriorate. This is a useful mod - recommended.
Post #243781 15th Jun 2013 11:27am
Page 2 of 2 <12
