![]() | Home > My Defender > My 90 - Rolling resto on a tight budget |
| frenchy Member Since: 05 Feb 2012 Location: Liverpool Posts: 133 |
Luvin the thread 007,
How are you getting on with your battery tray?? Had my 300tdi for a week now and have just removed the battery. Oh dear....... Its been held in place by not much more than good will. Whats your plan, cutting and welding? Would Isopon & Aluminium mesh be good enough as a short tem fix until MOT time:oops: |
| mymini007 Member Since: 10 Nov 2011 Location: Chippenham Posts: 273
thanks for the positive comments guys, keeps me going I am going to buy a battery tray, MOT is a good 9 months away, and its not too bad at the moment I am going to get one of these. http://www.yrm-metal-solutions.co.uk/021-n...x-13-p.asp I am led to believe they can just be riveted in! I am going to make my own inner van sides, Was going to put windows in, but I think I am just going to keep it as a van, as I have had a lot of use from it already. 6mm ply covered in acoustic carpet should do the trick. I have got my steering guard to try and fit today, and some more hoses to replace. RRUK, yours is looking great, you are inspiring me to get on too. But i dont have the budget you are working with, hence the blue peter approach to mine I have just thought of a name for it......... You cant polish a turd! But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
There are set templates, and I just added the hazard switch. wish I had not bothered with the extra holes for the dials. As i dont think I am going to use them. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
More shiny hoses
Top rad hose and and the top IC hose.. Click image to enlarge When i get a chance I might polish up the alloy This needs a clean up and fitting Click image to enlarge I need to have a play with this, not sure how i am going to connect it at the moment. Click image to enlarge Finally fitted the checker plate wing top, still need to paint the other side. And I really need to get my arse in gear and paint the bonnet and bulkhead. Click image to enlarge Not bad for a couple of hours, time to go and watch the rugby. 8) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
Thanks for the battery box info. Do you believe that they are riveted in on top of the existing or do you have to cut out the existing first?? Any one got any photos ? Go on then........whats it called |
If you google battery box fitting, I found a couple of threads this was the best one http://www.landyzone.co.uk/lz/f7/new-battery-tray-154812.html So cut out the old and rivet in the new. ...........Peter, as in blue peter.........I'll get my coat. You cant polish a turd! But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
T A X I !!!!!!!!!! |
Just been out for a test drive and it feels a lot more responsive, not surprising really as the IC pipe was being held on with cable ties, so must have been loosing boost.
I have just had a look at the upper rear ball joint and as I thought its knocking so that needs to be replaced, but I knew that. As it knocks every time I change gear. But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
Just sold my wheels. Gonna get some ATs, as the road noise is driving me nuts
Collecting new wheels tonight,
Freestyles from a Discovery ES, (grey inserts) I have become addicted to silicone. Will be getting a the full collant kit in blue for the next purchace. This one probably http://www.rimmerbros.co.uk/Item--i-RD1266...edium=feed So these are the next ones to go. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Jet washed the engine on saturday so on my drive to work today I was able to see if the hose fix had cured the oil leak. And I am happy to report that it seems to have worked, It also pulls so much better, I can get to 60 now with no effort at all. Where as before I was struggling to get to 50 and keep it there. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
007,
never mind "peter", she'll have to be called "pammy" cos' when you said.............
I thought you meant
007 likes this Pamela it is then But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
New feet and shoes fitted.
£100 + Original wheels Sold £100 - Chunky Wheels and tyres Bought £250 + Chunky wheels and tyres Sold £280 - BFG ATs and Freestyle wheels Bought So New wheels cost me £30 Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
