![]() | Home > My Defender > My 90 - Rolling resto on a tight budget |
frenchy Member Since: 05 Feb 2012 Location: Liverpool Posts: 133 ![]() |
Luvin the thread 007,
How are you getting on with your battery tray?? Had my 300tdi for a week now and have just removed the battery. Oh dear....... ![]() Its been held in place by not much more than good will. Whats your plan, cutting and welding? Would Isopon & Aluminium mesh be good enough as a short tem fix until MOT time:oops: |
mymini007 Member Since: 10 Nov 2011 Location: Chippenham Posts: 273 ![]() ![]() |
thanks for the positive comments guys, keeps me going ![]() I am going to buy a battery tray, MOT is a good 9 months away, and its not too bad at the moment I am going to get one of these. http://www.yrm-metal-solutions.co.uk/021-n...x-13-p.asp I am led to believe they can just be riveted in! I am going to make my own inner van sides, Was going to put windows in, but I think I am just going to keep it as a van, as I have had a lot of use from it already. 6mm ply covered in acoustic carpet should do the trick. I have got my steering guard to try and fit today, and some more hoses to replace. RRUK, yours is looking great, you are inspiring me to get on too. But i dont have the budget you are working with, hence the blue peter approach to mine ![]() I have just thought of a name for it......... You cant polish a turd! But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
There are set templates, and I just added the hazard switch. wish I had not bothered with the extra holes for the dials. As i dont think I am going to use them. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
More shiny hoses
Top rad hose and and the top IC hose.. ![]() Click image to enlarge When i get a chance I might polish up the alloy ![]() This needs a clean up and fitting ![]() Click image to enlarge I need to have a play with this, not sure how i am going to connect it at the moment. ![]() Click image to enlarge Finally fitted the checker plate wing top, still need to paint the other side. And I really need to get my arse in gear and paint the bonnet and bulkhead. ![]() ![]() Click image to enlarge Not bad for a couple of hours, time to go and watch the rugby. 8) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
Thanks for the battery box info. ![]() Do you believe that they are riveted in on top of the existing or do you have to cut out the existing first?? Any one got any photos ? Go on then........whats it called ![]() ![]() ![]() |
If you google battery box fitting, I found a couple of threads this was the best one http://www.landyzone.co.uk/lz/f7/new-battery-tray-154812.html So cut out the old and rivet in the new. ...........Peter, as in blue peter.........I'll get my coat. You cant polish a turd! But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
T A X I !!!!!!!!!! ![]() |
Just been out for a test drive and it feels a lot more responsive, not surprising really as the IC pipe was being held on with cable ties, so must have been loosing boost.
I have just had a look at the upper rear ball joint and as I thought its knocking so that needs to be replaced, but I knew that. As it knocks every time I change gear. ![]() But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
Just sold my wheels. Gonna get some ATs, as the road noise is driving me nuts
Collecting new wheels tonight,
Freestyles from a Discovery ES, (grey inserts) I have become addicted to silicone. Will be getting a the full collant kit in blue for the next purchace. This one probably http://www.rimmerbros.co.uk/Item--i-RD1266...edium=feed So these are the next ones to go. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Jet washed the engine on saturday so on my drive to work today I was able to see if the hose fix had cured the oil leak. And I am happy to report that it seems to have worked, It also pulls so much better, I can get to 60 now with no effort at all. Where as before I was struggling to get to 50 and keep it there. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
007,
never mind "peter", she'll have to be called "pammy" cos' when you said.............
I thought you meant ![]() ![]() |
007 likes this ![]() Pamela it is then ![]() But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
New feet and shoes fitted.
£100 + Original wheels Sold £100 - Chunky Wheels and tyres Bought £250 + Chunky wheels and tyres Sold £280 - BFG ATs and Freestyle wheels Bought So New wheels cost me £30 ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
