Home > Maintenance & Modifications > Reverse Camera Mounting Suggestions please
Page 2 of 3 <123>
It depends on how you want to set it up, but if you're having a separate screen then the switching between cameras is often a function that's built-in. For example, the screen I've bought has two inputs, one primary and one secondary. You connect the first camera - the one you'll use mostly - to the secondary input. This one could be switched on by a feed from the reverse light circuit. The second camera is connected to the primary input and operated by a separate switch (or perhaps a two way switch between them - the choice is yours). The clever bit is that when the screen detects a feed via the primary input, it automatically switches the display to that picture. Turn the second camera off again and it switches back to the first camera.
I don't know whether screens that are built into stereos have that function or not, but it's worth looking out for. Darren
Post #129411 7th Mar 2012 12:04pm
VeeTee
Netherlands
That's exactly the set up I boght from Ebay: link
Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #129417 7th Mar 2012 12:26pm
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
Can anyone who has fitted a rear view camera comment on how dirty it gets. Looking at the filthy state of my rear window at times, I would think it will need wiping clean very often. Don`t drive faster than your angel can fly!
Post #129454 7th Mar 2012 3:10pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Back a bit to an earlier post,
just for interest like - what is the large oval (ish) hole in the rear cross member meant to be for? I thought for towing electrics , but when mine arrived, they were mounted on the tow bar so it's not that (unless an extra set for something else maybe)
Doesn't seem to be any access to the drivetrain for a pto or anything like that so puzzled.
I don't want to put a camera in there and then find when I want to add x accessory that it needs the hole Very Happy
So what's it for? (I don't have it on my 1980 90)
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #129456 7th Mar 2012 3:35pm
Knot Yet
England 2012 Defender 110 Puma 2.2 USW Orkney Grey
If of any help - I have one of these:
http://www.trailervision.co.uk/index.php?m...cts_id=180
Fantastic bit of kit and although I use it for monitoring the dogs in the DC it can be used for multiple purposes including reversing
I bought one of their clearance models - not recon or used - just a grey instead of black screen surround. Give them a ring as they are very helpful - but product is first class and infact 100 times better than my actual reversing camera - which cost more than this did Rolling Eyes Defender 110 Puma Utility XS
Post #129458 7th Mar 2012 3:49pm
WarPig
d j hutton wrote:
Here's a link to the instructions, I'll look out the actual camera link in a mo.
Seems like you can link two together , say for example one at the front and one at the rear, so you'd probably be able to have two at the rear with a big long cable (pretty sure I have seen caravan trailer plugs on interweb)
[url]http://images.kenwood.eu/files/prod/2446/5/CMOS-210_310_(EN).pdf[/url] (not sure that link has worked, so might have to cut and paste it)
http://www.caraudiocentre.co.uk/product_m-...-26205.htm camera link - think its renamed cmos-310 now but same thing.
There is a two camera kit available as well http://www.dynamicsounds.co.uk/kenwood-rev...34215.html
hope this helps
DJ
Thanks DJ Thumbs Up
I changed your link slightly to get it to work..
That looks a neat camera, I wonder if it would connect to a standard monitor instead of a Kenwood head unit?
Sounds interesting, I like the idea of having two cameras for when im towing. And perhaps connected to a rear view mirror monitor that clips onto the existing mirror?
http://www.parkingcameras.com/store/produc...featured=Y
http://www.towsure.com/product/Rear_View_R...ied_Fitted
Post #129647 8th Mar 2012 1:14am
d j hutton
Yes it will connect to any monitor, I already checked that with kenwood in holland (can't find a number for uk customer support, only email)
Thanks for sorting out the link, couldn't get that to work at all.
The twin camera setup looks good as does towsure kit, but the cameras are quite big ones. I did look at the clip on the mirror idea, but as I'm having a screen anyway didn't take that any further, I understand they are good though (not sure if they fit between the sunshades though as the monitor looks quite wide - depending on who's site you get the measurements from Very Happy
Think I've sorted out the position and cable routing now though, so just need to flash the card and get it sorted.
Dj 1989 200tdi 90 csw
Buy British 🇬🇧
Post #129667 8th Mar 2012 9:20am
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
You can get those screens on ebay for about £30-40
Post #129669 8th Mar 2012 9:24am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
are the e-bay ones any good,looking for one with night vision.
Post #130825 12th Mar 2012 9:04pm
Comatra
Belgium
Hi tolley, the ebay ones are fine if you get them cheap enough Wink
The nightvision is something you have to like or not, me personally i'm not a huge fan. Because the image is no longer in color and goes to black and white. In most cases a non-IR camera will outperform a IR-camera since you never drive in complete pitch black darkness the use for 'nightvision' is rather over the top. I say this from my own experience with the cameras I have on my defender. When coming home at night, the rear is allready in 'nightvision' mode and my side cameras are still able to produce a nice color image.
In regards to cleaning, I've got a low mounted and does require a to give it the 'finger' from time to time Smile I mean, you swipe your lens with your finger Wink Caution, in contrast to our gorilla glass with anti-glare interior coating and dirt repelling outer coating, those ebay cameras sometimes have plastic lenses, so the finger swipe thing might damage your plastic.
Please check out this post, you can see some back up cameras on different defenders : http://www.defender2.net/forum/post130525.html#130525 Camera monitor systems: www.comatra.eu
TPMS systems: www.tp2.eu
Post #134275 25th Mar 2012 3:22pm
SGH
I was liking this one mainly as mirror has twin monitor built in....
http://www.ebay.co.uk/itm/Motorhome-Lorry-...2a1a3f3a12 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #134315 25th Mar 2012 7:36pm
tolley
SGH
they look good
Post #134339 25th Mar 2012 8:49pm
bilko
1986 Defender 90 300 Tdi HT Galway Green
Post #134354 25th Mar 2012 9:15pm
WarPig
Im considering one of these cameras (but in black) mounted above the rear door in place of the washer nozzle. The twin camera would be ideal for me, one for seeing my towbar when hitching up, and one for a general rear view picture. Perhpas connected to a rear view mirror monitor that either displays both images, or switches between the two?
I'd also like a white one fitted to the rear of my caravan.
Post #134385 25th Mar 2012 10:27pm
The only problem with one above the door is that you can't really see the tow bar as the spare is in the way. Darren
Post #134411 26th Mar 2012 12:25am
Page 2 of 3 <123>
