![]() | Home > Maintenance & Modifications > Air blasting up either side of cubby box! |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
Maybe the cover plate under the cubby isn't sealed very well? It does after all just open down to thin air above the gearbox.
A thin strip of household draught excluder down the sides could stop the draught. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
DavidITGuru Member Since: 16 Aug 2011 Location: London Posts: 99 ![]() ![]() ![]() |
I noticed this on mine too (during my brief tenure!) and assumed it was a 'feature' of Defender ownership.
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
yer no doubt it is the tray that goes over the hole, bit of sealer or duck tape will sort it out or buy the sticky back foam from land rover and renew the strip on the tray
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 ![]() ![]() ![]() |
that plate need some good insulation to be glued on it - on all surface. IN summer when temperature about 30C and higher cubby box becomes oven Puma 110
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Good point while it's off
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20863 ![]() ![]() |
This should do the trick for you: http://www.ebay.co.uk/itm/15-Metres-Double...1392wt_932
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Zag it's because you have the XS its the Land Rover aircon,
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
I was gonna say, I only really notice the draughts in mine when I drive naked 2005 TD5 90 Hard Top Beer 'n Sex 'n Chips 'n Gravy ![]() |
![]() Last edited by Zagato on 8th Mar 2012 8:56am. Edited 1 time in total |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I can't imagine there's any air escaping into the cabin with all the inches of gloop you've slapped on underneath that vehicle Zag
I used some sticky backed foam - took 5 mins to fix.
I'm going to do it all again this year ![]() ![]() ![]() ![]() Still haven't changed the gearbox oil after doing 4600 miles ![]() ![]() |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 ![]() ![]() ![]() |
4600?? That's nothing mines done 5700, mind you waiting for some better weather then it'll be dropped! Can't bring myself to crawl underneath in the wet at the moment ! Better do it before 6 k though or the box will self destruct.... ![]() |
Agreed to cold for such malarchy Jonno. Rossy changed his as soon as it came off the transporter
