![]() | Home > Maintenance & Modifications > Beware of Genuine Landrover SVX rear LED light kit... |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
The fitment of an LED indicator will not affect the operation of the trailer lights when using a resistor or LED flasher relay. The function of the dash tell tale will not work when using a LED flasher relay or when fitting LEDS to a trailer without the introduction of load resistors on the trailer.
I think Land Rover have discontinued the LED lights as a dealer option and I was told that Duckworth have bought a large consignment of them which they are trying to clear. We supply a number of dealers with our sets as they are all LED.
We would offer a two year warranty on our set as opposed to LR twelve months and also not charge £600 for a set. Would you like me to call today or tomorrow to see how I can help? |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Sorry to hear about the problem, I went through the options prior to purchase and found out the Lr ones we not led entirely, which seemed a bit misleading as they said led light kit in the brochure (mind you it also said leather gear knob as well) but it was hard info to come by.
Spent a bit of time on the phone to mobile centre a while back and bought a kit from them, still quite a lump of cash but couldn't get any joy out of the dealers when I wanted to buy them for pre purchase fitting. Mobile centre kit fitted straight on the original fixings and worked straight away, only about 1/2 hrs work, even for me, came with an indicator relay and all seems good. I'd be inclined to ask for a refund as you are not happy and buy a set from Tim at mobile centre , give him a ring, seemed to be a pretty organised crew, money taken, goods arrived next day, fitted that evening. Maybe not to everyone's taste, but the missus likes them and they are pretty bright lights, which is fairly important on something the size of a shed ! I understand you can get the same or similar result cheaper by buying bits separately but if you want plug and play then pay more and let someone else sort out the kit for you. Good luck with it. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 ![]() ![]() |
I had a set of these on my old td5 90 bought via Roverantics. Think theybare the same lights and were fantastic. Wish I'd kept them before selling the 90.
Using the relay supplied all lights including the trailer on std lights worked fine. The lights are very bright and certainly improve vehicle safety others see you much more clearly. Tim any change of a Defender2 deal for forum members ? ![]() ![]() ![]() ![]() ![]() Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
Check out the website pricing and then hit the phone, you never know ![]() Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
I have seen how the group buys work on here for our products
![]() Feel free to conatct me and I will try and sort a deal or a contribution to Martin. We try to do what we can to help but sometimes do not get it right 100% of the time. |
We are the cheapest on the web for these lights, I just checked on MUDs site and they are £398 + VAT and you still have to drill holes to fit the plinths, the plugs are supplied loose (unfitted) and you have to hack resistors in the loom to slow the flash rate down. The lamps have a one year warranty.
As said our kit is a full plug and play less than 30 minute install with the correct plinths, plugs fitted and plug in relay for £350 + VAT with a two year warranty. We also include gaskets and stainless screws. As DJ says you may be able to shop around and probably do it for a few quid less, but then you need to put it all together fit the plugs etc. |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
i've fitted the complete rear led light set, same make as supplied by LR but these included led indicators. I got around not re drilling the body work, by simply drilling holes in the plinths to match the original holes already there.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
A good idea on your part but also begs the question as to why they aren't made like that anyway? |
They are if you buy the proper Land Rover set (part from the indicators not being LED) or our set which includes the LED indicators
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
see the new haynes manual for fitting guide.....
I've just ordered a set of SVX lights from Tim at Mobile Centre, i'll post up pictures of the installation once received..... By the way, first impression of service from Tim is excellent with a reply to a PM at 11.30pm last night
