Home > Maintenance & Modifications > Black chequer plate
Black chequer plate
Does anyone know where it is possible to buy black chequer plate from either cut to measure or standardised size sheets? I am thinking of replacing the carpet on the underside of my rear tip up seats in my 90. I think somone else did the same on here? Thumbs Up
Post #127542 28th Feb 2012 9:45pm
T1G UP
what about the matting that looks like chequer plate?
Post #127543 28th Feb 2012 9:50pm
Skippy R
United Kingdom 1998 Defender 90 300 Tdi SW Chawton White
Where do you get that Question Dave
98 'S' 90 300Tdi (sold)
07 D3 HSE (now sold)
1993 Scania 143 450 (should have kept that ! )
Post #127550 28th Feb 2012 10:04pm
markb110
Hi Skippy
There is a feature in this months LRM
Accoustic matting from Wright Off-Road with a black chequer plate pattern
Mark
Post #127551 28th Feb 2012 10:08pm
Laurie
Buy ordinary checkerplate and have it black anodised.
That way, the cut edges are also black.
Post #127552 28th Feb 2012 10:11pm
I used stable matting - the advantage is sound proofing and it can be hosed out
available from mole valley farmers - just down the road
Post #127566 28th Feb 2012 10:55pm
Not sure rubber would be suitable for my use but I know the stuff you mean. I never thought about the edges on hindsight your right because when cut the edges would be silver. So you think the best idea would be to get regular chequer cut to size and then have it anodised. Where best do you think to get the chequer plating? Rebel 4x4? Thumbs Up
Post #127577 28th Feb 2012 11:15pm
Laurie
Check your local non-ferrous metal stockist. That would be the cheapest way.
May be listed as 'treadplate'.
Post #127581 28th Feb 2012 11:22pm
Skippy R
Cheers Mark I'll have a look at that. Was wanting to do something under my seats but it must be in black, only as a bit of extra noise reduction etc. Dave
Post #127594 29th Feb 2012 12:09am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Contact Patriot, as in the guys who make roof racks.
A mate said he had loads of it in stock, could be cheeper.
Post #127649 29th Feb 2012 11:33am
Thanks for the info all of you. At least it's only square cut pieces and not shaped and also flat so shouln't be to bad. Thumbs Up
Post #127662 29th Feb 2012 12:14pm
