![]() | Home > Maintenance & Modifications > Black chequer plate |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
what about the matting that looks like chequer plate?
Skippy R Member Since: 08 Feb 2012 Location: Yorkshire,out 'n'about Posts: 160 ![]() ![]() ![]() |
Where do you get that ![]() 98 'S' 90 300Tdi (sold) 07 D3 HSE (now sold) 1993 Scania 143 450 (should have kept that ! ) |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2682 ![]() ![]() ![]() |
Hi Skippy
There is a feature in this months LRM Accoustic matting from Wright Off-Road with a black chequer plate pattern Mark |
Buy ordinary checkerplate and have it black anodised.
That way, the cut edges are also black. ![]() |
I used stable matting - the advantage is sound proofing and it can be hosed out
available from mole valley farmers - just down the road |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
Not sure rubber would be suitable for my use but I know the stuff you mean. I never thought about the edges on hindsight your right because when cut the edges would be silver. So you think the best idea would be to get regular chequer cut to size and then have it anodised. Where best do you think to get the chequer plating? Rebel 4x4?
Check your local non-ferrous metal stockist. That would be the cheapest way.
May be listed as 'treadplate'. ![]() |
Cheers Mark I'll have a look at that. Was wanting to do something under my seats but it must be in black, only as a bit of extra noise reduction etc. Dave
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
Contact Patriot, as in the guys who make roof racks.
A mate said he had loads of it in stock, could be cheeper. |
Thanks for the info all of you. At least it's only square cut pieces and not shaped and also flat so shouln't be to bad.
