![]() | Home > Puma (Tdci) > Gap door/window |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Didn't realise that. Lets hope it's well painted inside there then!
Pete |
I think the fewer nooks and crannies the water can sit, the fewer places that will rust. If it has to drain, then better just at the corners and straight down. That's why I'll fill the middle section in... Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
I have sealed my corners and on members motors, it can still get in but not so much and only when it rains heavily
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
mines the same - rubber not wide enough..... or should I be saying due to the poor qa and excessive tolerances in the manufacture of the door the rubber strip won't fit as intended.....
should I ask for a new door ![]() |
Are you a gambling man ![]()
Of course - I have it ready and waiting ![]() Incidentally, are there many vehicles designed to trap water coming off the windows in a gutter and then channel it to soak the steel inside the doors? ![]() But shout it at them in German because life is also terrifying and confusing... |
![]() the dealers are going to love me..... new door please.....and while you're at it - new seats (paint rusting / flaking off) head light bezels (rusting) mud flap brakets (rusting) oh and perhaps they can have another look at the drivers lock that sticks closed when cold. ![]() |
Rust issues on a Defender are really something you will have to address yourself. They can replace most of it out but it will only happen again unless you treat it yourself....you will have to anyway when the warranty runs out.
Once the new parts have been replaced, treat it all and you won't have any problems. Some parts can be changed for SS parts like the bezels for a permanent solution of course ![]() |
thanks (I'm just being lazy) - any suggestions on the seat frames tho?
I plan to send you a pm soon (that could be a few days tho till I get round to it) ![]() |
Buy a decent firm seat that's well-designed and doesn't ![]() But shout it at them in German because life is also terrifying and confusing... |
Are the seats rusting on the weld points or is it on the actual tubing and brackets. If it is localised on welds I would rub down, acid convert with Ku-Rust or similar then paint. If it is more widespread it depends how good you are with painting/masking./spraying etc! Otherwise it's back to the dealer who will probably send it off to be done but I would stay with the vehicle and make sure they do it properly
![]() ![]() A lot of the metal on these motors isn't undercoated properly or at all ![]() ![]() |
Have you had much success with Ku-Rust? Tell someone you love them today because life is short.
Yes it stops it dead. It only does surface rust though (fine for seat frame rust!) so need to wire brush, shot/sand/soda blast etc most of the rust off or for smaller parts dip in one of the rsut stripping solutions. Plenty of other products which are the same and can be used in a more bulk capacity although I did two axles and other bits with one small pot of Ku-rust with POR-15 over the top, Sorted for good
![]() ![]() ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
