![]() | Home > Puma (Tdci) > wont start and alarm wont work. |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 ![]() ![]() ![]() |
i`ve managed to sort it with the advice of a friend, turns out the fob had lost its sync to the alarm, managed to resync it, but still have the question of the alarm antenna wire,
all the information on here says it should be orange with a grey trace but i have a black wire coming from the loom then the black covering is stripped back to reveal a white wire with metal sheathing around it (just like television aerial cable) the white wire then goes in to the left rear terminal of the left hand plug and the metel sheathing goes in to the left front terminal. do you think the white wire is the antenna and the metal one is to sheild from interferance ???????? LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4807 ![]() ![]() |
I was left one key short when I bought the 2011 Puma. Finally got the missing one posted up from the selling dealer. They arranged for a nearer main dealer to program it for me.I got it programmed but it is a mess up. When the new key is inserted- nothing. I have to press the lock then unlock on the fob to get it to work. I do this with the key in the ignition. This proves that it is a fob programming that is at fault as the original one works o.k. Will get it sorted at first service at a different maindealer.Maybe your fault is similar. Just a thought. 1982 88" 2.25 diesel
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
what year is it?
on the later one it's already extened it comes right next to the center vents in the middle of the dash, just behind the time clock. why do you need to extend the range,mine is 10x better than my td5 maybe you battery needs changing in your phob? Cheers Ash |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
If you want to extend the range then just hold the fob to the skin of your forehead when pressing the button. Range increased by about 200%.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
pm sent
hi landyash,
range is not to bad from the front but have to stand at back door for it to work from behind, changed battery with no differance. thanks lorryman, pm replied ![]() |
