Home > Puma (Tdci) > thunk/thunk from rear of 110
Page 2 of 3 <123>
JWL
Just as an aside, I didn't get the noise on my last 90, but that had an aluminium skinned door. I think the steel skin on these later doors "drums" a lot more, bit like the solid side panels on the hard tops.
Post #100012 15th Nov 2011 12:29am
spudfan
Ireland
My 2008 Puma has the same door as the 2011 Puma but does not do it. It could be a simple adjustment of the receiving unit for the door lock could solve it. I have started adjusting mine but it will be trial and error (or pure good luck) to gt it sorted. It is just a matter of loosening the two bolts holding the receiver in place then shifting it slightly. I will probably still be posting updates this time next year! Anyway if it is the position of the receiver that causes this noise then all the maindealer will do is adjust it too. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #100081 15th Nov 2011 3:26pm
spudfan
Ireland
Just a thought. Has the rear suspension been uprated to the stiffer heavier duty type to comply with the new commercial classification? If so that would explain the "jump" on sharp bumps instead of the smooth ride over them. 1982 88" 2.25 diesel
Post #100747 18th Nov 2011 5:11pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Have a good look at the door catch 'receiver' - the bottom of my back door is rubbing (again, having been sorted before under warranty) on the door sill plate and wearing down to the steel - the bottom plate on the receiver casting is curved or bent compared to photos on the web...looks like the cast material is too soft/thin to support the weight and movement of the door and spare wheel. 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #101972 23rd Nov 2011 4:45pm
spudfan
Ireland
Have a look at the rubber block on the receiver. Mine was slack. Tightening the screws did not work as one was too long and protruded through the bottom of the block. When the door was closed there was slack between the rubber block and the latch mechanism on the driver's door. This allowed movement on bumps. I removed the longer screw and fitted washers between it and the block. Before this I inserted a small washer between the top of the rubber block and the metal cap.Big improvement. Door is tighter as there is a tighter fit between the rubber block and the latch on the door. 1982 88" 2.25 diesel
Post #102302 24th Nov 2011 8:54pm
22900013A
I'm still getting the clunking from the back of my 110. I have tried to wiggle the door on its hinges but there is no movement, with door open of closed. I have got rid of any lose items from the back, tried the seats folded down and put back to useable layout...no difference. So what the heck is it? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #103189 28th Nov 2011 10:13pm
spudfan
Ireland
Thougfht this had cured it but sad to say it is still there. Might not be the door at all. 1982 88" 2.25 diesel
Post #103205 28th Nov 2011 10:54pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
By Jove, I think I've cured it....!
I think (not 100% sure) that in my case it was the second row seats moving up and down.
I noticed there was a lot of free play in the seat catch, allowing the seat to move up and down by about 5mm.
I folded the seat (larger of the split seats) forward, added a couple of 5cm square layers of noisekiller rubber I had lying about, under where the seat base buffer touches the floor.
Folded the seat back upright (took a bit more of a slam to get it to catch), and there was noticeably less movement.
Drove over some of my usual bumpy roads, and so far it seems to have cured it! Thumbs Up
Saying that, I also removed my Thule roof bars on the same day, so that could have contributed - I'm always amazed just how much roof bars stiffen the bodywork up - Doesn't help that Defender bodies have the structural rigidity of a lettuce leaf. Rolling Eyes
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #104536 4th Dec 2011 6:00pm
spudfan
Ireland
I have an adjustable tow hitch fitted. Here is a picture of it.
http://www.landrover.com/gb/en/lr/defender/accessories/
LR007222
When the plate with the towball is removed-no more thunk thunk.When the plate with the towball is refitted the thunk thunk starts again on bumps.I must fit a piece of rubber ie. part of an old mudflap,between the plate and bracket to stop this noise.Give it a try and it might solve your problem. 1982 88" 2.25 diesel
Post #126414 24th Feb 2012 4:22pm
Happyoldgit
My rear door will make a similar noise if only on the first latch. Why not try moving the rear door striker in a gnats and see if that makes any difference [outline it on the pillar in pencil first before moving it then you can put it back where it was if it makes no difference]. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #126463 24th Feb 2012 7:52pm
spudfan
Ireland
Tried adjusting the rear door but without success. Only thing that works is taking off the towball plate.Only takes a couple of seconds so i do not mind. 1982 88" 2.25 diesel
Post #126466 24th Feb 2012 8:09pm
bwanashamba
2011 Defender 130 Puma 2.4 HCPU Alpine White
check out your rear shock absorber rubber bushes, when they are worn and have alot of play it realy clonks when going over a bumpy road, get someone to bounce the rear of your puma while you look for play in the rubber bushes.
Post #126846 26th Feb 2012 1:11pm
spudfan
Ireland
One of the first things I checked,just over 4000kmsso all o.k. there. 1982 88" 2.25 diesel
Post #126864 26th Feb 2012 3:27pm
Zagato
Rear seat belt knocking on side maybe Confused
Post #126881 26th Feb 2012 4:55pm
Zagato
I get this also, it's more of a donk noise, had it from new Confused Wondered if it was diesel slapping around in the tank but it sounds more mechanical Confused
Post #129202 6th Mar 2012 6:21pm
Page 2 of 3 <123>
