![]() | Home > Puma (Tdci) > Service recalls |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Mynstral,
Welcome to the forum and to the Puma club. Regarding your question the easy way to know if a recall is pending is to registered yourself in the www.landrovertechinfo.com known also as http://topix.landrover.jlrext.com (its free!) After registered, with your VIN (SALLXXXXXXXXX) you can check if a recall is pending. Regarding other issues a lecture of the forum post will be very good. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
Thanks for the post Eduardo-I too will benefit.
Mynstral Member Since: 14 Feb 2012 Location: Essex Posts: 119 ![]() ![]() ![]() |
Thanks Eduardo.
I have MY2010 and so far...
1. transfer box rear oil seal 2. door closing jobbies (the metal door things that keep the doors open) 3. crankcase breather pipe heater (only for extreme cold climates) that's about it ... maybe check headlight bezels and any other rusty bits showing .... |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Rear Window Heater, if fitted, can have heating circuit damaged by high level brake light pod. Replacement has a modified heating grid. Symptoms of failure - top 3 heater elements fail.
I've also had the front door stay torsion bars replaced and the transfer box rear oil seal. 2010MY 90 XS. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
nice one WelshGas - forgot about that one ...had mine done too
What is the issue with the door stays? Steve.
Not exactly a recall but changed without any hassle. Front doors have a torsion spring type arrangement to click into place when they are at bout 75* open and keep them open. It releases when pulled shut, against the resistance of this torsion spring. Neither of mine would stay open. Hence changed under warranty.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Are you very sure that the actual torsion bars were changed? On mine I just tightened the bolts and they started holding the doors as normal.
Cheers Nick |
Ah got you. Mine were like that but cured it by tightening the bolts too. That said the drivers door stay has ripped through the door seal so I'll be asking for that to be replaced when it goes in for service next month. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I tightened them up at first - mentioned this at the 1st service and they changed them at the next visit when they did the transfer box seal. LANDYWATCH
